ᐅ What type of external venetian blinds (also known as louvered shutters) should be used?
Created on: 5 Jan 2020 12:24
tumaa
Initially, I planned to use external venetian blinds (raffstores) in the living areas and roller shutters in the sleeping areas.
Now I want to use external venetian blinds exclusively. I have the following Roma models to choose from:
- hemmed edge
- Z-lamella
- CPL
Can someone give me a tip? I’m not sure which type I should choose.
Thanks and best regards!
RotorMotor
20 Sep 2021 19:49
We have decided to use Z-lamellae everywhere.
This is essentially a symmetrical cross-laminated timber (CLT) and can therefore also be installed with an upward slope.
The "bend" in the Z shape makes the lamella stiffer and ensures a tighter fit.
Araknis20 Sep 2021 20:54
guckuck2 schrieb:
Unless you plan to sleep during the day
That actually happens to me quite often.
guckuck2 schrieb:
Also keep in mind that you’re in the living room, while the kids are often in their bedrooms. Why should they sit in the dark?
If I understand the sentence correctly: Even with roller shutters, there is something between fully closed and fully open. It’s just that with venetian blinds (or external blinds) it looks nicer.
Chloe83
20 Sep 2021 23:04
And what happens when you sleep at night and there is a storm outside? Do the roller shutters go up in the middle of the night, or how should I imagine that?
I don’t have this issue with roller blinds. At least not in the bedroom.
Has anyone heard of the Roma DBL (triple-curve slat), not the CDL slat, and can share some information about it?
Araknis21 Sep 2021 09:12
Chloe83 schrieb:
And what happens if you sleep at night and there’s a storm outside? Then the roller shutters go up in the middle of the night, or how should I imagine that?
With traditional shutters, I don’t have this issue. At least not in the bedroom.
In the worst case, that is exactly what happens.
RotorMotor
21 Sep 2021 09:16
In the bedroom, we chose roller shutters as the only option.
However, it should be noted that this window is now not aligned on the same level as the windows with Venetian blinds.
This does bother me a bit...
Tolentino21 Sep 2021 09:25
Warning: This is just a claim (I have no practical experience yet): A fully closed venetian blind, especially one with CDL slats or similar in a guide rail, is just as resistant to wind as a roller shutter. In fact, at wind speeds strong enough to tear such a blind out of its guide, large branches are already flying around that would also damage a roller shutter. When such storms are forecast, you can proactively raise the venetian blinds manually.
For now, I won’t be installing a wind sensor. But maybe next year I’ll be complaining about it here.
