ᐅ Using Kallax Shelving as a Bar: Are Liquids a Concern?
Created on: 3 Jan 2022 19:47
Nondi9
Nondi9
3 Jan 2022 19:47
I’m currently considering using an Ikea Kallax shelving unit as a bar – specifically for storing and displaying spirits, mixers, and glasses. My question is: Are liquids such as high-proof alcohol, mixed drinks, or syrups problematic for the shelves themselves?
I understand that Kallax shelves are made of wood-based panels that are coated, but how vulnerable are they to potential damage from spilled or leaking liquids? Could these affect the stability or appearance of the shelving unit? Especially in a bar setting, moisture and occasional spills seem almost inevitable.
Do you have any experience using Kallax as bar furniture, particularly regarding handling liquids? What precautions would be advisable to prevent damage? For example, would using coasters or special protective films be recommended?
Looking forward to your helpful insights, thanks!
mabla
3 Jan 2022 20:12
Wood-based panels are sensitive to moisture, especially if they are frequently exposed to water. It is best to use coasters and immediately clean up any spilled liquids. Otherwise, the material will swell and suffer permanent damage.
Lorukeo
4 Jan 2022 08:34
The question of whether liquids are a concern can be clearly answered from a technical perspective: Kallax shelves are mostly made of particle board or medium-density fiberboard (MDF) coated with melamine resin. This protective layer is water-repellent but not completely waterproof.
mabla schrieb:
Wood-based panels are sensitive to moisture, especially if they get wet frequently.
This means that spilled or leaking liquids, if not removed quickly, can penetrate the surface. As a result, the material will swell in the affected areas, which not only affects the appearance but also reduces the stability of the panels.
For use as a bar, I therefore recommend:
- Generally using protective films or covers on the shelves that are easy to clean.
- Always using coasters under bottles and glasses.
- Wiping up any liquids immediately.
Additionally, sealing the exposed edges could help, as these are particularly vulnerable.
Rodolfo
4 Jan 2022 10:56
One additional point: High-proof spirits contain alcohol that does not damage the protective coating. More problematic are sugary or colored mixed drinks and syrups, which tend to be stickier due to their consistency and ingredients and are harder to clean up if spilled.
Lorukeo schrieb:
Spilled or leaking liquids, if not removed quickly, can cause the surface to become damp.
Therefore, it is important to keep bar surfaces easily accessible to quickly clean up spills. It might also help to place a thin glass sheet on the Kallax unit; this maintains the appearance while making cleaning easier.
mabla
5 Jan 2022 12:40
Nondi9 schrieb:
Are liquids, such as high-proof alcohol, mixed drinks, or syrups, potentially harmful to the shelves themselves?
In short: Yes, if they are not cleaned up promptly. Use coasters, absorb any spills immediately, and everything will be fine.
