ᐅ Can Kallax corners break with frequent moving?
Created on: 11 Oct 2023 09:17
tanner_lau
tanner_lau
11 Oct 2023 09:17
I am currently considering getting a Kallax shelving unit because I really like the flexibility and modular design. However, my main concern is whether the typical corners of the Kallax modules are prone to breaking or cracking with frequent transportation, such as moving or changing the location often.
I understand that the shelves are designed to be stable, but has anyone experienced that damage tends to occur more often at the joints or corners? Or are these areas durable enough to withstand repeated transport? This is important for me to know, as I might want to rearrange or take the shelving unit with me regularly. Thanks for your insights!
jan10
11 Oct 2023 09:39
Kallax shelves are generally sturdy, but the corners can crack open if subjected to strong impacts. This can happen during frequent transport without adequate protection. Proper packaging and careful handling are important.
lajudo
11 Oct 2023 10:02
I can confirm that the Kallax edges are stressed by assembling and disassembling multiple times. However, if done carefully without any sharp impacts, the risk of damage is minimal.
CARLA
11 Oct 2023 12:14
Regarding the structural load capacity of the Kallax corners, it should be noted that they are made of particleboard with a melamine coating, which generally provides high stability under static loads. However, signs of wear from frequent movement mainly occur at the glued or joined edges, especially at the corners.
The composite material is robust but not designed to withstand repeated heavy mechanical stresses from transport or frequent repositioning. As a result, damage may occur due to localized loads or impact forces.
Therefore, enhanced padding during transport or shipping the parts separately is recommended to extend the lifespan and prevent cracks.
Ramon4
11 Oct 2023 13:22
CARLA schrieb:
Wear and tear from frequent movement mainly occurs on glued or jointed edges, especially at the corners.
That’s true, I have a Kallax myself that I’ve moved around several times. It’s important not to grab the shelves just by the corners or push them against walls during transport. Small damages add up quickly, especially when the shelves are moved often.
benon
11 Oct 2023 15:05
I would add that especially the connecting screws and dowels used in the Kallax units can loosen with frequent assembly and disassembly. Particularly when the corners are often under stress, the shelf may lose stability and the risk of breaking increases.
Regular inspections and tightening of the screws when necessary help to minimize damage.
