ᐅ Lawn mowing robot is here – which one do you use and what are your thoughts on it?
Created on: 8 Feb 2021 23:57
Tarnari
As mentioned above, we want to get a robotic lawn mower to start the spring season.
Which ones do you use, recommend, or avoid, and why?
Does it have to be a Husqvarna, or is a Worx also good enough? Why one and not the other?
I’m very interested in hearing about your experiences.
Tarnari
hippjoha
27 Feb 2021 23:10
rick2018 schrieb:
Gardena requires the gateway for coverage. Husqvarna has an integrated SIM card with lifetime service. That is very convenient.
I have built a smart home, but so far I haven’t connected my robotic mowers.
However, I don’t have a use case like yours.
Hi Rick,
thanks for the info. How is the connection to the Gardena gateway? Via Wi-Fi? From what I’ve seen so far, I might be able to implement my scenario with it. A reed switch reports an open door to my KNX binary input —> command via Home Assistant (which I use as visualization server and logic engine) to the robotic mower
Nida35a27 Feb 2021 23:32
Tarnari schrieb:
So, do you also have a 1000 sqm (10,764 sq ft) robot for that area?
We have the 750 model for 300-350 m² (3,229-3,767 sq ft), which is sufficient.
Tarnari27 Feb 2021 23:59
Sounds good, then we are on the safe side. Now I just have to hope that everything runs smoothly tomorrow and nothing goes wrong. I really don't need a cable break or anything like that. xD
rick201828 Feb 2021 05:22
@hippjoha The gateway is connected via LAN or WiFi and then creates its own WiFi network.
Tarnari28 Feb 2021 15:02
So, the job is done. Luna—our little one named the robot that—runs its rounds diligently and finds its way back without any issues.
Now I need to work on the coverage areas and operating times. Are there any best practices for that?
And one more question: Gardena recommends not operating the robot below 5°C (41°F) and to remove it when there is a risk of frost. Is this really that critical? How do you handle this?
Nida35a28 Feb 2021 15:19
Ours is still put away, and the grass isn’t really growing vigorously. Once everything has been mowed, we’ll wait for the start of the season.
