ᐅ During the installation of the roof panels, the coating was damaged.
Created on: 20 Jun 2018 22:18
schwede133S
schwede13320 Jun 2018 22:18Hello,
We ordered the Unik roof tile profile from the company DS-Stahl. We chose Palux 30µm (30 microns) as the coating. The sheet metal has a thickness of 0.5mm (0.02 inches).
During installation, I noticed that the coating is partly missing. This affects the screw holes where the screws were driven through the sheet metal, as well as the overlaps between the sheets.
As a layperson, I am now wondering about corrosion. If the coating is missing, does that mean the long-term corrosion protection, which is guaranteed for 25 years, is also missing?
HilfeHilfe21 Jun 2018 07:24schwede133 schrieb:
we ordered the Unik roof tile profile from DS-Stahl. For the coating, we chose Palux 30µm (1.2 mil). The sheet metal has a thickness of 0.5mm (0.02 inch).
During installation, I noticed that the coating is partially missing. This affects the screw holes, where the screws were driven through the sheet metal, as well as the sheet overlaps.
As a layperson, my question is about corrosion. If the coating is missing, does that mean the long-term corrosion protection, which comes with a 25-year guarantee, is also missing?Photos?
When you drive screws in, a bit of the coating always comes off. That’s normal, isn’t it, or should it be glued on?
HilfeHilfe schrieb:
When you screw in, some coating will always come off. That’s normal, right, or should it be glued?Washers could effectively reduce the scraping off, for example...
