Do you have any tips or tricks for affordable temporary solutions (until next spring) for our gravel-covered terrace/courtyard?
What do you place on the gravel or bare ground during transitional periods before the outdoor area is finished to still enjoy the sunlight on the terrace while minimizing the amount of stones tracked into the house?
Of course, it should be as low-cost as possible since work on the outdoor area is scheduled to start in spring 2023.
I appreciate any advice.
Benutzer20022 Apr 2022 12:27Prager91 schrieb:
Of course, everything should cost as little as possible, since the exterior work is scheduled to start in spring 2023.Concrete slabs given away for free on eBay Classifieds, must be picked up by yourself. If necessary, they can also later serve as the base for a wooden deck.Benutzer200 schrieb:
Free concrete slabs from eBay Classifieds, must pick up yourself. They can later serve as a base for a wooden deck if needed.I was also considering concrete slabs, but they are currently not available in my area...
We still have about 70cm (28 inches) height difference from the terrace door to the terrace, so we will probably bridge this area with pallets (possibly with an OSB board on top) and then cover the area where the table will be placed with outdoor rugs – I think this is the most cost-effective solution.
The gravel is actually already very well compacted, and the small stones on the back terrace are manageable. With rugs, it should definitely be sufficient.
Out front in the yard, it’s a bit tricky... The effort will probably be higher there. We currently have some wooden planks lying around.
Benutzer20022 Apr 2022 12:41Prager91 schrieb:
We still have about 70cm (28 inches) of height difference from the terrace door down to the terrace, A 70cm (28 inches) height difference is quite significant. You'll definitely need to build stairs.
Prager91 schrieb:
I had also considered concrete slabs – but at the moment, I can’t find any in my area... Really? Online there are plenty all across Germany offering their slabs for free.
