ᐅ Telecom FTTH – What Is Needed?
Created on: 29 Mar 2020 18:40
Golfi90
Hello everyone!
In the next few weeks, our FTTH connection will be activated by the telecom provider.
I received a fiber optic router from an acquaintance. It is not from the telecom provider!!
Unfortunately, I can’t find any option in the configuration to enter login credentials...
With FTTH technology, does the router automatically authenticate itself?
Or will the router not work with the telecom provider’s connection?
The router is a Genexis Platinum-7840 fiber optic router.
Lumpi_LE
29 Mar 2020 19:55
You should try googling FTTH routers; about a year ago, I found a list of which ones work. I think there were about five. Or you could pay the 5€ rental fee for the one from Telekom, which is supposed to be pretty good.
hanse987
29 Mar 2020 20:33
With FTTH from Telekom, there is a fiber optic modem. A router is connected to it. The advantage is that the router does not need a modem. What kind of setup do you have at home? Maybe yours works without any issues.
If you need to buy one, first figure out what features it must have. TAE ports? S0 interface? DECT functionality? Excellent Wi-Fi or does it not matter because everything runs through access points? VPN? Any other necessary functions?
Golfi9029 Mar 2020 20:50
I don't really see the point in paying monthly rent to the telecom provider. That’s why I wanted to arrange my own router in advance.
The router doesn’t need to do much—just serve as a DHCP server.
The Wi-Fi will be distributed via two access points.
From what I’ve found so far, my router apparently comes from the German fiber optic network. As Rick already mentioned.
So it should support fiber optic connections, right?
Tarnari29 Mar 2020 21:08
Just to clarify for my understanding – are you referring to the modem or the router?
The type of router shouldn’t really matter, as any should work. It’s best to use a gigabit router.
The critical point is actually the modem, which is either integrated into a router or connected before the router.
Have the modem provided by the telecom provider (if it’s also a router, disable the routing function) and then connect any router that meets your requirements behind it.
Renting might sound unpleasant at first. But honestly, paying a few euros for the security that the connection (without routing) works and that you get a free replacement in case of a defect would be worth it to me.
Golfi9029 Mar 2020 21:25
If the telecom provider includes the corresponding modem free of charge, then everything is fine. I guess I’ll have to ask again...
dhd82
29 Mar 2020 21:26
Last year, during the construction of our new house, Telekom installed FTTH for us. The access data is stored in the router (the modem is provided by Telekom).
We decided against using Telekom’s own router and chose a product from Ubiquiti (USG-Pro-4) instead. However, this is not a combination device, meaning it does not provide Wi-Fi, for example.
