ᐅ Space requirements in the utility room for a centralized ventilation system
Created on: 29 Nov 2015 17:21
sirhcHello,
I’ve been trying for a while to determine the space requirements in the utility room for a central ventilation system. Could you name some common manufacturers? That might help me move forward.
We are currently planning the sizing of the utility room in the basement.
It will need to accommodate:
- Washing machine
- Dryer
- Gas condensing boiler
- Main unit of the central residential ventilation system
- Unclear: whether a water storage tank (connected to solar) will be installed there
Additionally, I’m interested in the space needed for a modern gas condensing boiler.
Thank you in advance.
- Washing machine
- Dryer
Ours is suspended from the ceiling. So it requires virtually no floor space.
A controlled residential ventilation wall unit, which is what is typically installed, requires roughly the same space as a washing machine... a condensing boiler needs about half that amount.
Everything you listed we managed to fit into 4.5m² (48.4 ft²)... I wouldn’t recommend it, but that is roughly the minimum size for all that equipment...
So, we somewhat underestimated the space requirements for the brine-water heat pump. The unit itself is only about the size of a refrigerator, but it stands roughly 20cm (8 inches) away from the wall due to the piping. The heating circuit distributor is also positioned somewhat awkwardly in the room. The water main connection cannot be overlooked either – well, everything is close to the floor, but it’s obviously not possible to fit a washing machine or dryer there.
Our utility room is 8sqm (86 sq ft) and will likely be quite full.
