ᐅ Retrofitting Soft-Close Drawer Slides for IKEA Metod Cabinets with Minimal Effort
Created on: 13 Jan 2017 08:23
dangla
dangla
13 Jan 2017 08:23
I’m planning to retrofit soft-close functionality to my IKEA Metod kitchen drawers, but I want to do this with minimal effort and without fully removing the drawers or carrying out complex modifications.
I’m especially interested in whether there are simple retrofit kits that can be attached directly to the existing drawer runners without needing much tooling or altering specific components.
Are there any experiences with retrofitting soft-close dampers to Metod drawers without having to take the entire drawer out? Which solutions work best, and are there options that can be installed quickly and easily without advanced technical knowledge?
I’m looking forward to your tips and advice!
meole
13 Jan 2017 09:17
Hello dangla,
I find your topic very interesting because soft-close really greatly improves the comfort of a kitchen. About a year ago, I considered something similar and also wondered how much effort it would take. To be honest, at first I was afraid of damaging something.
It’s true that some kits are very simple and you only need to loosen a few screws to install the dampers. However, you should make sure that the parts are exactly compatible with Metod – if there are other drawer systems, it can get tricky.
Also: sometimes retrofitting is barely worth it if the drawers are quite old or already heavily used. In those cases, I almost considered a complete replacement.
Of course, I hope others here will share their experiences with soft-close retrofitting to give you the best advice.
leomo
13 Jan 2017 09:53
meole schrieb:
I had similar thoughts about a year ago and was also wondering how much work it would take. Honestly, at first, I was scared of breaking something.
Haha, that’s exactly how I felt on my first try too! 😅
I can only say: with a little patience and a good screwdriver, it’s easy to do. A soft-close damper is basically a small helper that you screw in or clamp next to the slides. You should measure carefully beforehand and read the installation instructions – that’s the most important part.
My tip: just don’t rush it, and the soft-close runners will be installed quickly, finally putting an end to slamming drawers! 😉
klabe
13 Jan 2017 11:11
to approach the topic in a more technical way, here is a brief guide for retrofitting the soft-close feature on IKEA Metod drawer slides:
- First: Check which type of slides you have (e.g., 3-part Metod rails)
- Purchase compatible soft-close modules, preferably IKEA originals or compatible brands
- It is usually advisable to remove the drawer to get better access to the rails
- Soft-close dampers are typically installed on the rear rail, often using screws or clips
- Follow the installation instructions carefully, making sure no parts get stuck
A common mistake is not fully removing the drawer, which makes it harder to install the dampers. My tip: take your time and work systematically. This will help avoid crooked screws and malfunctions.
Summary: Retrofitting is quite doable but usually requires at least partial removal of the drawers. It is often difficult to do without tools and removing the drawers.
LAYNE
13 Jan 2017 14:07
klabe schrieb:
Without tools and removal, it usually gets difficult.
I have to agree with you, but I solved it like this: I only pulled the drawer out slightly, just enough to reach the rails at the back. Then I carefully hooked the dampers from underneath without disassembling everything.
This worked great for me, and I only needed a small screwdriver. Of course, it takes a bit of fiddling, but if you don’t want to take everything apart right away, this is a practical solution.
Oh, and a little patience is key. This way, you can retrofit the soft-close feature without much effort. 😎
Louie
14 Jan 2017 08:36
I would like to add that there are different types of soft-close systems, especially for IKEA Metod:
- Complete sets for the Metod drawer that attach onto the existing runners
- Retrofit dampers, usually fixed to the back or along the runners
If you want a particularly minimal effort, clip-on systems are recommended, which you can simply snap on without screws. However, you should carefully check whether your drawers allow this.
Another tip: Make sure that the drawers are not loaded too heavily, as this reduces the soft-close effect.
If anyone feels unsure about installation instructions, just ask! I’m happy to help.
