ᐅ Found a replacement for the KALLAX back panel?
Created on: 30 Oct 2021 21:37
torapra
torapra
30 Oct 2021 21:37
I am currently redesigning my IKEA KALLAX shelving unit and am urgently looking for a suitable alternative to the original back panel, as mine was damaged. It is important for me to find a solution that is as stable and visually clean as possible, easy to install, and fits the typical KALLAX dimensions.
Has anyone here already found a reliable replacement for the back panel? I am especially interested in proven materials or DIY options that can be used without relying on the original part.
Looking forward to your tips and experiences!
Juan31
30 Oct 2021 22:03
Regarding "Replacement for KALLAX back panel":
I have already examined various options, as the original back panels are made of relatively thin hardboard and can be easily damaged. The best replacements are MDF boards with a thickness of 3-6 mm (0.1-0.25 inches). They are more stable but can still be easily cut with a utility knife or jigsaw.
If appearance is important, a white lacquered or laminated MDF that closely matches the original look is recommended. The panels are best attached with small screws into the side crossbars or by using clamp strips.
A small note: particleboard is too heavy and tends to swell more when exposed to moisture. Plastic panels (e.g., HPL) are durable but difficult to cut yourself without the appropriate tools.
In summary: 4 mm (0.15 inches) white laminated MDF is the best DIY solution as a replacement for the KALLAX back panel.
KUDAISY
31 Oct 2021 08:22
Hello torapra,
I can only confirm Juan31’s suggestion. Here is a brief guide on how you can make the back panel yourself:
1. Take measurements: The standard KALLAX back panel is about 77 cm (30 inches) wide and 39 cm (15 inches) high for the 4x4 unit, but it’s best to measure yourself precisely, as dimensions can vary with special models.
2. Material choice: Purchase a 4 mm (0.16 inch) MDF board, white laminated or painted to protect against moisture.
3. Cutting: Many hardware stores now offer free cutting services, which ensures a straight edge.
4. Installation: It’s best to attach with small round-head screws (3x12 mm (0.12x0.47 inch)) or, if you want to avoid screws, secure it on the back with double-sided mounting tape.
Common mistakes:
- Panels that are too thick, making insertion difficult
- Edges that aren’t clean, causing the panel to jam
- Fitting the panel too tightly — it should have a slight clearance to avoid warping
This approach definitely reduces effort and keeps a neat appearance.
bensau
31 Oct 2021 11:17
KUDAISY schrieb:
Typical mistakes: Boards that are too thick – make installation difficult
Basically means: No armor steel, otherwise the Kallax just won’t fit! 😉
Jokes aside – I once used a simple plywood panel as a back wall and sprayed it with paint to make it look nice. It was super easy, looked great afterward, and held up well. Of course, MDF is more stable, but for a small budget and DIY factor, plywood is a good alternative.
Just one tip: Be sure to sand the edges carefully, otherwise you’ll get unpleasant splinters—especially if you have kids or pets at home. And don’t skip a thin coat of varnish for protection.
In my opinion, if you enjoy crafting, it’s definitely worth trying 🙂
Sinan-meo
1 Nov 2021 17:45
Juan31 schrieb:
Particle boards are too heavy and tend to swell more with moisture
I can only agree with that. I would even add: If both appearance and durability are equally important, using a thin HDF board for replacement back panels is worth considering. It is harder and smoother than MDF and considerably more resistant than regular hardboard.
In addition, I have had good experience using double-sided tape to fix the back panel. Screws can easily damage the wood, especially with repeated sliding in and out of shelf cubes.
For those skilled with DIY: You could also try sturdy plastic sheets (e.g., matte-finished acrylic), which are very robust and available exactly in the KALLAX dimensions. Installation can be a bit tricky, but the look is definitely eye-catching.
I hope this is helpful.
