ᐅ Replacing Paint Chips on a BILLY Shelf – Step-by-Step Guide
Created on: 8 Feb 2019 10:17
Dapefo
I have a Billy shelf from Ikea that unfortunately has some paint chips in several spots. I would like to repair the damaged areas to restore it to its original condition. However, I’m unsure of the best way to proceed to achieve a clean and durable result.
Specifically, I’m looking for a step-by-step guide, starting with properly cleaning the damaged areas, then sanding and preparing them, and finally applying paint or lacquer that matches the original finish as closely as possible.
Are there particular products or techniques recommended for the thin particleboard used in the BILLY shelf? Do I need to observe specific drying times, or can the work be done in multiple stages?
I would greatly appreciate a detailed instruction, preferably including recommendations for materials, tools, and any tips for common pitfalls.
Thank you in advance!
CHARLES69
8 Feb 2019 21:08
I just did this on my own BILLY – the most important thing: never apply too thick a layer! Multiple thin coats are key, otherwise the paint will crack or peel off quickly.
And be sure to let it dry patiently; if you rush, everything may seem fine at first, but later you’ll have problems with chipping.
About the paint: use an acrylic brush and a touch-up pen together to make the surface as smooth as possible!
It’s brilliant when the shelf looks like new again! 🙂
TANBI
9 Feb 2019 09:57
Just a tip: Before painting, consider using wood filler for small dents to create an even surface. After it dries, sand lightly and then paint. Without leveling, the surface often ends up uneven.
Lucki
10 Feb 2019 11:22
Wow, how much fun fixing things is once you get the hang of it! 🙂
One last tip: when painting, use a very fine sanding pad between coats. This gives you the ultimate finish and a perfect look!
You can do it, the results will make you really proud! Good luck!
