ᐅ Removing Paint Scratches from a BILLY Shelf – DIY Tips
Created on: 11 May 2018 09:13
Kaneni
Kaneni
11 May 2018 09:13
I have noticed some paint scratches on my IKEA Billy bookcase that really bother me, as the shelf is painted white and the scratches are quite visible. The surface is painted, not laminated, so simply wiping it down does not help.
I am specifically looking for DIY tips to repair these paint scratches myself or at least reduce their visibility. What works well on white painted panels like this? Should I use special touch-up paint pens, polishing compounds, or home remedies?
It is also important to me that the solution lasts in the long term and does not leave the surface dull or blotchy. If anyone has experience with BILLY bookcases or similar surfaces, I would appreciate advice on preparing the surface and the actual repair process.
Thanks in advance for your helpful tips!
tinau
11 May 2018 09:47
Just use a white paint marker from the hardware store. Clean the surface thoroughly, then apply the paint. Let it dry – this usually gives good results.
Nicksin
11 May 2018 10:22
Hey Kaneni, paint scratches are always annoying – I had the same issue with my BILLY. White nail polish worked really well for me. Don’t apply it too thickly and be patient while it dries 🙂. It works surprisingly well and is quick to do!
Josan
11 May 2018 11:56
Hello Kaneni,
Your question is very clearly formulated – that really helps when looking for advice. I’d like to add: Before applying a touch-up pen or paint, gently clean the surface and then carefully smooth the edges of the scratches with very fine sandpaper (around 1000 grit). It’s important not to sand too much to avoid removing all the paint.
After that, apply several thin layers of the appropriate touch-up paint, allowing each layer to dry thoroughly in between. This will help you achieve the smoothest possible surface. For cleaning, a mild dish detergent and a soft cloth are best to avoid causing further damage.
If you like, I can also recommend specific touch-up pen brands that I used for my BILLY mishaps.
SETHBLA
11 May 2018 12:18
I agree with tinau: touch-up paint pens are the best solution. It’s important that the pen matches the exact color. Pure white from the hardware store usually works well. Clean the surface beforehand, apply with light pressure, and you're done.
Kaneni
11 May 2018 15:07
Josan schrieb:
I would like to add: Before applying a touch-up pen or paint, I would gently clean the surface and then carefully smooth the edges of the scratches using very fine sandpaper (around 1000 grit).
That sounds very helpful, thank you!
Are there specific types of sandpaper recommended for use on painted furniture? I only have coarse sandpaper at home and definitely don’t want to cause any more damage.
Also, I’m curious if anything should be applied after using the touch-up pen, such as clear coat for protection, or if that’s sufficient as is?
