ᐅ Reinforcing a KALLAX unit with a wooden beam afterward – how to insert it?
Created on: 24 Dec 2021 14:07
bradken
bradken
24 Dec 2021 14:07
Some time ago, I bought an IKEA KALLAX shelving unit, and due to space constraints, I would like to significantly reinforce it. My idea is to insert wooden beams (dimensional lumber) into the existing compartments to increase stability, especially under heavy load.
My specific question is: What is the best way to place the wooden beams cleanly and precisely into the KALLAX? Is it enough to just lay them in, or should they be fixed in place as well? How can I prevent the beams from slipping or the shelf from warping?
I’m also interested in tips for choosing the right wooden beams (dimensions, type of wood), and whether it’s advisable to make any modifications to the shelves or back panels before inserting the beams.
I appreciate all experience reports and detailed advice on this topic!
fepau
24 Dec 2021 15:39
Wow, what a great project! 🙂
I’ve also reinforced a KALLAX shelving unit with timber beams before – and I can tell you, it adds a lot of stability! I cut the beams precisely and simply placed them inside the cross compartments. It’s important that the wood fits exactly, ideally cut with a router or at least a fine jigsaw.
I didn’t attach the beams separately; they fit kind of like an insert and hold firmly, especially once the shelf is loaded.
My tip: If you glue the beams to the shelf with some wood glue beforehand, it will be even more stable – but if you want to take the shelf apart later, you can of course skip the glue.
Good luck, this is brilliant, it really gets more out of the furniture!
SUBEN60
24 Dec 2021 17:04
fepau schrieb:
I did not fasten the wood pieces extra; they fit somewhat like an insert
This method is generally acceptable, but the exact fit of the squared timber is crucial. I recommend using squared timber with a slight interference fit to prevent any movement.
For fastening, using a solvent-free wood glue is advisable to create a strong, lasting bond. Alternatively, small wooden dowels can be used, but for this, it is recommended to prepare appropriate drill holes to ensure stability.
The wood pieces should be carefully measured and cut before installation to avoid any warping of the shelf. It is also advisable to lightly sand the surfaces before inserting them to improve the adhesion of the glue.
Regarding material choice: Softwood squared timber with edge dimensions of 20x40mm (about 0.8x1.6 inches) generally offers a good balance of weight and strength.
Parbo
25 Dec 2021 10:18
Hello bradken,
I can understand your concern well, as the KALLAX shelf can reach its limits, especially under heavier loads or when used as a room divider.
Regarding the approach:
1. Material selection: Softwood beams, preferably spruce or pine, with dimensions of 20x40mm (0.8x1.6 inches) are sufficiently sturdy without adding unnecessary weight. Hardwood would be stronger but is generally more expensive and heavier.
2. Cutting: The beams need to be cut precisely to fit the dimensions of each shelf compartment. It is essential that there are no gaps to prevent the shelf from twisting. A fine miter saw blade or a table saw is suitable for this.
3. Inserting and fastening:
- I recommend making small tongue-and-groove joints along at least one edge or attaching the beams directly with wooden dowels and glue.
- Additionally, a sturdy back panel can be fixed to the rear of the shelf as a cross brace.
4. Follow-up questions: What kind and how much load is planned? Will the shelf stand freely, or will it be fixed to the wall? How much experience do you have using woodworking tools?
These details are important to provide you with targeted assistance.
If you like, I can also prepare a step-by-step guide for you.
kloreo
25 Dec 2021 11:03
bradken schrieb:
How should the dimensional lumber be placed neatly and precisely into the KALLAX?
Cut the dimensional lumber exactly to size, leaving no gaps. Insert it directly and glue it to the inner sides with wood glue. Do not use nails, as they can damage the material.
Parbo schrieb:
What kind and level of loads are planned?
That would be helpful information, as the approach depends on it.
Laurence
26 Dec 2021 09:27
I would like to add something fundamental, as the stability of the KALLAX primarily comes from the combination of the sides, shelves, and back panel.
If you want to insert wooden battens afterwards, the back panel should be kept under tension at the same time. Without a securely fixed back panel, the shelving unit quickly loses rigidity under load, even if the battens are firmly in place.
It is also important that the battens are not only placed but also connected to the bottom surface of the shelving unit and, if possible, to the sides. Gluing with wood glue at several contact points ensures optimal distribution of forces.
Another helpful tip: securing the shelving unit to the wall increases safety significantly.
Unfortunately, it is common to see battens simply fitted loosely – this provides some support, but not full stability.
I hope this helps you with your project! 🙂
