ᐅ How to Spot Poor Workmanship in Built-In Shelving – Tips for Buyers
Created on: 10 Apr 2017 07:23
Edifar
I am considering buying a Billy shelving unit but have some concerns about the quality of workmanship. Especially with affordable furniture, you often hear about poor gluing, warped shelves, or unstable joints.
My question is: How can you best tell in-store or at the dealer if a Billy shelf has poor workmanship?
Are there typical areas where weaknesses can be quickly identified? Which details should I check carefully to avoid being disappointed later?
Even small cracks, uneven surfaces, or wobbly edges could be signs of low quality for me. Could you share your experiences on what to look out for?
Thanks in advance!
Penau
10 Apr 2017 13:09
Additional notes:
Pay particular attention to the clearance between the side panels and the shelves. Irregularities here can indicate material warping.
The back panel is often made of thin hardboard. If screws and nails are not properly installed, it offers little stability.
It is recommended to carefully check all joint points for secure gluing and correct alignment. An uneven groove on the sides or loose connection tabs are signs of poor workmanship.
Since Billy is a standard product, batch quality can sometimes vary. A side-by-side comparison on site is therefore advisable.
chenValeri
10 Apr 2017 14:17
Edifar, also make sure to check if the shelf wobbles when touched lightly. If it does, steer clear.
LEAH_TAN
10 Apr 2017 15:28
I’ve had my Billy for years and I’m happy with it! 🙂 It’s important to take your time before buying and check everything carefully. If you don’t overload the shelves, it will last really well!
A tip: pick up the shelf in the store, move it around a bit, feel the surface – this will quickly help you tell if it feels high quality.
Good luck, you can do it!
Mathiasche
10 Apr 2017 17:54
Hello Edifar,
From experience, I can say that the quality of Billy shelving units can vary depending on the store and the specific delivery. Therefore, it is always a good idea to compare several units.
Another tip is to pay attention to parts that cause problems during assembly. For example, if screws or dowels don’t fit properly or if the wood splinters.
If the shelf feels noticeably wobbly or creaks after assembly, caution is advised. If possible, ask for help with the assembly in the store or request assistance putting it together.
If you order it online, check carefully for damage multiple times when unpacking and report any issues immediately.
farli
10 Apr 2017 18:22
LEAH_TAN schrieb:
Pick up the shelf in the store, wiggle it a bit, feel the surface – then you quickly get a sense if it feels high quality.
Really? The surface alone doesn’t say much about durability. I wonder if people rely too much on visual or tactile qualities and overlook the internal joints.
The shelf can look great, but if the back panel is poorly fitted or the connections aren’t precise, it won’t last long. The question is how to objectively identify these internal weaknesses without tools or a lot of time.
Does anyone have a method to reliably detect such internal defects?
farkin
11 Apr 2017 08:37
farli schrieb:
Does anyone have a reliable method to detect such internal defects?
Good question!
I actually recommend a simple “stability test” using your hand:
- Gently wiggle the partially assembled shelf back and forth: listen for noises like creaking or cracking.
- Press diagonally against the shelf with your hand to feel for any play in the corners.
- Check the connections between the side panels and the back panel. Are they flush? Can you feel any gaps?
This method requires no tools and provides real insight.
If it’s too loose, you’ll notice it immediately.
Regarding appearance, I admit it shouldn’t be the sole criterion. However, poor workmanship almost always shows up visually as well.
So, a combination of visual inspection and tactile testing gives a good overall assessment.
