ᐅ How to Spot Poor Workmanship in Built-In Shelving – Tips for Buyers
Created on: 10 Apr 2017 07:23
Edifar
Edifar
10 Apr 2017 07:23
I am considering buying a Billy shelving unit but have some concerns about the quality of workmanship. Especially with affordable furniture, you often hear about poor gluing, warped shelves, or unstable joints.
My question is: How can you best tell in-store or at the dealer if a Billy shelf has poor workmanship?
Are there typical areas where weaknesses can be quickly identified? Which details should I check carefully to avoid being disappointed later?
Even small cracks, uneven surfaces, or wobbly edges could be signs of low quality for me. Could you share your experiences on what to look out for?
Thanks in advance!
farkin
10 Apr 2017 07:46
Hello Edifar,
your question is very good because the Billy shelf does have a few common weak points that should be checked before purchase. I’ll divide this into three areas:
1. Material inspection: Take a close look at the shelves. Make sure the boards are flat and even. Warping or uneven surfaces indicate poor workmanship.
2. Gluing and edges: Check the edges for clean finishing. Loose or poorly glued edges are a warning sign. Small cracks often appear here first.
3. Stability test: If possible, assemble the shelf in the store or gently press against the back panel and shelves. If it wobbles a lot or creaks, that’s not a good sign.
In summary, visual and tactile inspection is very important. I also recommend comparing several units.
If you like, I can create a checklist with points for you to go through.
chenValeri
10 Apr 2017 08:02
Always check the back panel! In cheap shelving units, the back panel is often too thin or warped, which significantly affects the stability.
pauPierce
10 Apr 2017 09:15
I would like to add to the points made by farkin and chenValeri. The Billy shelf is generally well designed, but often it is the small details that determine the overall quality.
In addition to the mentioned points, you should also consider the following:
- Screws and wall plugs: Check if the screw holes are properly pre-drilled and not frayed. Loose or poorly fitted wall plugs can cause wobbling.
- Surface finish: The laminated coating should be free of air bubbles and have clean edges. This usually reveals whether the product was cheaply made.
- Shelf sagging: Especially for longer shelves, thin material may bend if too many books are placed on them. Questions to ask: How thick are the shelves? Can they remain stable under a load of around 10 kg (22 lbs) or more?
- Back panel and brackets: Verify if the back panel is squarely fitted. Misaligned back panels are often the main cause of instability.
It would be helpful to know exactly where you plan to place the shelf. The load and intended use are important factors for assessing it.
Do you already have an idea of the size and weight capacity you are planning?
Edifar
10 Apr 2017 11:03
pauPierce schrieb:
It would be important for you to know exactly where you want to place the shelf. Load capacity and intended use are key factors for evaluation.
Good point! The shelf will be in my study, primarily for books and folders. The load could easily be around 15–20 kg (33–44 lbs) per shelf. That’s why stability and minimal sagging are important to me.
Regarding size, I’m leaning toward the standard model, 80 x 28 cm (31.5 x 11 inches) depth, 202 cm (6 ft 7.5 in) height.
Do you recommend ordering stronger shelves, or are there no alternatives with the Billy system?
farkin
10 Apr 2017 11:32
Edifar schrieb:
Do you support the tip to order stronger shelves, or are there no alternatives with Billy?
The shelves in the standard Billy are about 16 mm (5/8 inches) thick and quite firm. There are officially no thicker shelves available individually for higher loads, except for the wider "Width 80" version, which is somewhat more stable.
One option is to have MDF boards cut to size at a hardware store and use them instead of the supplied shelves. MDF is often more load-bearing.
When purchasing, it is important to also check the holes for the shelf supports. Cheap material can often crack here. It’s worth inserting the supports carefully without forcing them.
I also recommend paying extra attention to straight edges and flat shelves when buying—this small effort can save you from problems later on.
