ᐅ How to Carry Out a Low-Budget Land Survey?
Created on: 29 Sep 2021 15:18
Rumbi441
I would like to know how steep an undeveloped plot of land is.
Is there an affordable DIY method to measure this accurately to the centimeter (inch)?
I don’t want to hire a surveyor for this; I just need a rough initial idea.
Rumbi441
29 Sep 2021 15:55
Can I operate this as a "standard" user?
Steffi33
29 Sep 2021 15:58
Hmm, no idea.. in this case, only "trial and error" helps… if you meant the app.. the same applies to the leveling device.
Interrupt
29 Sep 2021 16:00
Alternatively, you can try the analogue method and use a water level hose. The hose obviously needs to be long enough. Then, by observing the water level in the hose, you can determine the height difference relative to the ground level. This method only works for gentle slopes or if you have a ladder.
Elokine
29 Sep 2021 16:01
A truly low-budget method would be: one person stands "above" with a spirit level and laser, while the other is "below" with a tape measure. --> Laser hits the tape measure. This way, you know the height difference and can calculate the rest.
If the slope is longer than the tape measure length, you can repeat this in sections until you reach the bottom.
This should be sufficient for a rough estimate.
Rumbi441
29 Sep 2021 16:16
That’s a cool idea. I’ll put the laser on a one-meter (3.3 feet) tall tripod so I can measure it precisely. Amazing. I’ll report back on how it went! I can get the GPS coordinates from my phone, so I’ll have a rough idea of my location. Great!
haydee
29 Sep 2021 16:22
Have you already tried the Geoportal Bayernatlas?
