I would like to know how steep an undeveloped plot of land is.
Is there an affordable DIY method to measure this accurately to the centimeter (inch)?
I don’t want to hire a surveyor for this; I just need a rough initial idea.
I bought a laser level for 10 euros, attached it to a rod with a flat board, and drove it into the ground. Then I fixed a strip of wood to it on which I mounted a measuring stick to walk around the property. That was sufficient for our planning.
I also tried various apps, but they didn’t help much as they were much less accurate.
haydee schrieb:
Have you already tried the Geoportal Bayernatlas?In what way? I can see the plot there, but nothing more.Rumbi441 schrieb:
2 meters (6.6 feet) difference over 40 meters (131 feet)... that’s what you get. It’s more flat than a slope 🙂Ahem *** if you say so? Basically, the building envelope should be the relevant factor – and if it states 150, you should be more precise in your planning: The basement comes into play and, depending on orientation, offers a good but more expensive foundation compared to standard construction.
