Hello everyone!
I just realized, to my horror, that our two-month-old oak furniture piece is infested with pests.
There is very fine-looking sawdust on our glass shelves.
I noticed this when unpacking it back in October and wiped it off, assuming it came from transport or manufacturing.
What should I do now? I have, of course, contacted the seller directly, but I’m also worried about my other wooden furniture in the room and our roof beams. 🤨
What do I need to do or what can I do to prevent further damage?
kati1337 schrieb:
I also don’t really see why I should take care of getting rid of the pests. The cabinet is 3 months old, so the seller should be responsible.
...It may be necessary to prove that the infestation was already present when the furniture was delivered. A phone call will clarify whether the seller is willing to take responsibility. At least in our circle of acquaintances, the carpenter was very cooperative.kati1337 schrieb:
I’m more worried that the problem might spread to nearby furniture. Is that likely?
...Almost any wood with sufficient moisture and density can serve as food! The furniture should be removed from the home immediately or at least wrapped in plastic sheeting.AxelH. schrieb:
Wikipedia provides information under "common furniture beetle." The risk of infestation spreading to other wooden parts mainly exists in the next generation of these small pests, following the idea of "let’s find a nice nest with enough food for our little ones." I need to look up how long a generation typically lasts. But even that won’t help me much since I don’t know how old the wood is.
I’ve now arranged with the seller to have the sideboard picked up as soon as possible. We will then receive a replacement gradually, since it is currently not in stock. It might be by the end of February.
I’m considering asking if they would take the item back completely. Maybe I should also get rid of the other two pieces of furniture and buy completely different living room furniture. (?)
Would you attribute this to the quality of the furniture? Or can an infestation occur occasionally even with genuine solid wood furniture? I’m honestly quite shocked.
hampshire15 Jan 2021 11:27Such an infestation should not occur, but it can happen occasionally. If the other furniture shows no signs of infestation, they are fine. Stick to the manufacturer and product line, since you didn’t choose them without reason, and assume you simply had bad luck with an isolated case. Don’t let it bother you.
In fact, there are reports online that this can happen when buying furniture. I would have assumed it was more common with antiques, as proper precautions should be taken during furniture manufacturing.
If such an issue goes unnoticed, it can lead to serious problems. In cases of (very) severe infestations, you can even hear the pests "smacking" when they are resting at night. No joke. But we are probably far from that here... 🙂
