ansgarm7431 Mar 2011 21:04Hello,
we want to cover our interior walls with Fermacell boards. What is the best tool for cutting the boards (circular saw, jigsaw)? What is the best way to fasten the boards (screws or nails)?
Regards
A. Müller-Wissmann
Regards
A. Müller-Wissmann
fischaqua10 Apr 2011 16:34Hello,
I cut the panels using a circular saw with an old saw blade. I fastened the panels with screws.
Regards, Matthias
Regards, Matthias
ansgarm7419 Oct 2011 22:03Hello,
I’m revisiting the question.
How did you connect the panels to each other?
Did you install the panels simply without gluing or filling the joints (I don’t mean filling the joints or using screws)? What experiences have you had with panels installed this way?
Regards,
Ansgar
Regards,
Ansgar
Regards
A. Müller-WissmannHello!
Insufficient answers often indicate that the question is unclear.
What exactly are you planning? Do you want to refurbish existing walls – for example, in an older building? What is the substrate like? Why choose gypsum fiberboards (Fermacell) instead of gypsum plasterboard?
Or do you want to construct interior walls with a lightweight frame? Which type of stud frame – wood or aluminum?
I’m a big fan of Fermacell, but working with it can be unpleasant due to the dust it generates!
Usually, walls with a stud frame are built as fischaqua described. I would attach gypsum plasterboard directly to existing masonry.
TomTom1
ansgarm7420 Oct 2011 19:32TomTom1 schrieb:
Hello!
Insufficient answers usually indicate that the question is unclear.
What are you planning to do? Do you want to cover existing walls, for example in an older building? What is the substrate like? Why use gypsum fiberboards (Fermacell) instead of drywall (gypsum plasterboard)?
Or do you want to construct interior walls using a lightweight frame? Which type of stud frame – wood or aluminum?
I am a big fan of Fermacell, but working with it is quite unpleasant due to the dust it produces!
Typically, walls in stud frame construction are built as fischaqua described. For existing masonry, I would attach gypsum plasterboard sheets.
TomTom.The boards were delivered to our house by the builder.
We have a wooden stud frame.
Hello!
So, back then we
- screwed the panels to the substructure. However, self-drilling screws are not necessary for wood
- filled the joint with Fermacell gypsum compound (no idea if it contains additives)
- sealed the Fermacell-to-Fermacell joints in the ceiling area with acrylic sealant
- sealed the connections to the masonry with silicone.
Today, I would
- consider using reinforcing tape (some panel joints are still visible)
- seal all connection joints between ceilings and walls with silicone (which is now apparently also paintable).
TomTom1
So, back then we
Today, I would
TomTom1
