ᐅ Poor Wi-Fi in a Newly Built Home Despite Fiber Optic Connection
Created on: 20 Nov 2020 22:31
Tx-25
Hello. Today, after 6 months, we finally got internet in our new build. I set up the fiber optic connection on the FritzBox 7590 router. For that, I reset the router to factory settings and configured it according to the fiber installation guide. Then I updated it to the latest version. Somehow, the Wi-Fi isn’t as fast as expected. What could be the reason? The router is located in the utility room (ground floor corner) on a cabinet. Our living room is in the opposite corner on the ground floor. There, we have 3 out of 4 bars, sometimes even less. The speed is not particularly good either.
In the upstairs bathroom (directly above the utility room), the connection is practically non-existent. If I go to the upstairs hallway, I get 3 bars. Shouldn’t the signal actually be stronger throughout, even without a repeater?
The fiber modem and the FritzBox are connected by an Ethernet cable I already had. Should this cable be upgraded? Are there any other tips?
The switch for the LAN outlets isn’t connected yet. I still need to order it and install the wiring.
nordanney21 Nov 2020 00:23This is not a fiber optic issue (what kind of contract do you have?), but purely a Wi-Fi matter. The problem could be the FRITZ!Box itself or its placement.
goalkeeper21 Nov 2020 00:26We also have the 7590 and no reception directly on the 1st floor. The concrete ceilings, steel, and underfloor heating do not help the Wi-Fi signal.
Therefore, access points should ideally be planned at critical locations in the house during new construction.
Which telecom plan have you actually subscribed to?
Tx-25 schrieb:
These are the details from the FritzBox.
Internet Connection
IPv4: connected since 20.11.2020, 14:57, Telekom, internet access speed (available bitrate): ↓61.8 Mbit/s ↑12.4 Mbit/s
IPv6: connected since 20.11.2020, 14:57, Telekom, internet access speed (available bitrate): ↓61.8 Mbit/s ↑12.4 Mbit/s
Test internet connection speed?
I’ll test tomorrow what arrives and try switching the phones from the 2.4 GHz band to the 5 GHz band today. That should improve things, right? If these are definitely the main data of the Fritzbox for your connection and you have fiber optic with a DL 250+ plan, then it’s definitely not a Wi-Fi issue.
That doesn’t rule out that you might still have one. Depending on conditions—walls, refrigerators, mirrors, plants—you can experience significant signal loss over just 2 meters (6.5 feet).
