ᐅ Poor Wi-Fi in a Newly Built Home Despite Fiber Optic Connection
Created on: 20 Nov 2020 22:31
Tx-25
Hello. Today, after 6 months, we finally got internet in our new build. I set up the fiber optic connection on the FritzBox 7590 router. For that, I reset the router to factory settings and configured it according to the fiber installation guide. Then I updated it to the latest version. Somehow, the Wi-Fi isn’t as fast as expected. What could be the reason? The router is located in the utility room (ground floor corner) on a cabinet. Our living room is in the opposite corner on the ground floor. There, we have 3 out of 4 bars, sometimes even less. The speed is not particularly good either.
In the upstairs bathroom (directly above the utility room), the connection is practically non-existent. If I go to the upstairs hallway, I get 3 bars. Shouldn’t the signal actually be stronger throughout, even without a repeater?
The fiber modem and the FritzBox are connected by an Ethernet cable I already had. Should this cable be upgraded? Are there any other tips?
The switch for the LAN outlets isn’t connected yet. I still need to order it and install the wiring.
lastdrop schrieb:
Maybe the problem is actually with the "glasfiber." Something seems to have gotten mixed up there...You mean it's reversed? *LOL*https://www.instagram.com/11antgmxde/
I was also surprised that the Wi-Fi in the attic of our new build is so weak. We have a FritzBox in the utility room connected to the fiber optic modem with a 50 Mbit/s plan (MagentaZuhause M).
There is an Ethernet outlet in every room. If you have the same, it's best to use one outlet for an access point.
