ᐅ Optimal Planning of Ikea Metod Kitchen Cabinets for Limited Space Conditions
Created on: 21 Dec 2023 10:17
sydneyHello everyone,
I am currently planning an Ikea Metod kitchen for a very small apartment where space is extremely limited. The challenge is to make the most efficient use of the available area without making the kitchen feel cramped or losing important functions.
I already have some experience with kitchen planning, but I am still uncertain about choosing and arranging modules in tight spaces. Specifically, I am interested in:
- How can storage space be maximized in Metod systems so that everything essential fits even in small kitchens?
- Which modules do you consider especially suitable for narrow kitchen layouts or corner solutions without compromising movement space?
- Are there any tips for designing work surfaces to be as functional as possible when working with limited area?
- How do you handle seating areas or small dining tables near the kitchen, if present?
I am really looking forward to your practical advice and perhaps some creative ideas that go beyond the standard setup. Thanks in advance!
Hello sydney,
I can fully understand how challenging it is when the space is so limited, yet you don’t want to compromise on comfort.
For me, that was a big challenge. I tried a lot of things back then and finally installed very deep pull-outs in the base cabinets, which provide a huge increase in storage capacity. I would also definitely recommend well-thought-out interior fittings, like pull-outs with compartments, to keep pots or spices organized and easy to find.
Narrow tall cabinets (20-30 cm wide) work well to make practical use of the space—for example, as a pantry or spice rack. Corner solutions with carousel cabinets are very helpful in small corners because they cleverly use areas that would otherwise be difficult to access.
I completely understand the concern that everything might feel cramped. I addressed this by using light-colored fronts and limiting open shelves, as these can easily overwhelm the eye when too full.
If you like, I can share some more details from my planning.
sydney schrieb:
How can storage be maximized with Metod systems so that everything important fits even in small kitchens?
sydney schrieb:
Which modules do you consider particularly suitable for narrow kitchen lines or corner solutions, without compromising movement space?
It is an excellent idea to choose the Ikea Metod system here, as it provides a flexible foundation that can be especially well adapted to small spaces. The technical features and design options are extremely important during the planning phase.
In detail, I recommend first conducting a precise room analysis. This means taking exact measurements including all projections, radiators, windows, and door openings to avoid errors in the planning process.
For maximum storage space in small kitchens:
- Generally, use the deepest cabinets (max. 60cm (24 inches) floor depth), but check if reduced depths can be used when needed to gain more freedom of movement.
- Choose drawers with full-extension runners instead of doors, as they significantly improve access to the back areas.
- For corner cabinets, I recommend the "Magic Corner" system, which optimizes access.
- Tall cabinets with internal pull-outs that use the space up to the ceiling as much as possible, if spatial conditions allow.
- Use pull-out pantry units for narrow niches – very efficient for bottles and spices.
Regarding the work surface:
- Use a single-piece countertop cut as much as possible to avoid unnecessary gaps.
- If possible, work with fold-out solutions, such as drop-leaf countertops that can be expanded as needed.
- Integration of built-in appliances (brewing unit, microwave with convection) saves space.
On the topic of seating areas:
- If space allows, I recommend small upright tables or fold-down tables that can be folded away against the wall when not in use.
- Seating benches with storage underneath are also a good option.
It would be helpful to know the exact room dimensions to give more precise advice. Hopefully, this serves as a helpful initial overview.
Here are some quick tips:
- In small kitchens, always choose pull-out drawers instead of doors.
- Use corner solutions like carousels or magic corners.
- Narrow tall cabinets provide extra storage without taking up much space.
- Keep the countertop clear and uncluttered; otherwise, the space feels tighter.
- Integrate fold-down tables or pull-out surfaces for seating areas.
Functionality takes priority over design in small kitchens.
In addition to the previous posts, I would like to emphasize the importance of a structured approach to planning, which is essential especially in confined spaces:
- First, create an accurate floor plan with precise measurements down to the millimeter.
- Prioritize kitchen functions: cooking, washing, storage, and workspace—define and arrange them logically.
- Ikea Metod offers standardized widths: 20, 40, 60, 80 cm (8, 16, 24, 32 inches); use these modularly and avoid gaps between units.
- For work surfaces, I recommend a depth of 60 cm (24 inches) for ergonomic and practical reasons.
- Use corner solutions with suitable cabinets, such as "Magic Corner" or "Le Mans," to reduce dead corners.
- In small kitchens, it is better to avoid too many wall cabinets, as they can quickly make the space feel visually cramped.
- Light-colored fronts and well-planned lighting help make the room appear more spacious.
It is important that the functions are not limited by the furniture layout. A well-thought-out plan maximizes usable space while enhancing user convenience.
