ᐅ Placing KALLAX on supports – what do you use?
Created on: 14 Jun 2024 08:37
Supilis
I am currently planning to place my KALLAX shelving unit on supports to make better use of the floor space and possibly create a kind of floating effect. My specific question is: What types of supports or wall mounts do you use to install a KALLAX so that it stands securely but with as little visual weight from floor feet as possible?
I am interested in both materials and fastening methods, especially how you assess potential loads and any tips you have for proper sizing.
Thanks in advance for your practical advice and experiences!
Greglau
14 Jun 2024 15:06
Metal brackets, depending on the load, fixed with 5 mm (0.2 inch) or 6 mm (0.24 inch) screws, and wall anchors suitable for the wall. Drywall requires special hollow wall anchors. Alternatively, attach wooden beams behind the drywall and then secure the supports to them.
Supilis
15 Jun 2024 08:18
Update from me: I have now decided on sturdy steel brackets and ordered Fischer cavity wall anchors for drywall.
Load-bearing capacity was important to me because I want to use the area as a small bookshelf. Thanks to everyone for the advice, especially the tips on anchor selection were very helpful!
KNUTGI
15 Jun 2024 09:44
Great that you’ve made your decision! 😊 Remember to distribute the weight evenly and regularly check that everything is still secure. A bit of maintenance always pays off. And hey, adding some style with wood or metal elements really enhances the look of the KALLAX.
Davidleo
15 Jun 2024 10:03
That sounds great, have fun with your shelf! 🙂 Especially if you’re putting a lot of books on it, safety is really important. We’re cheering for your project!
KAULIS
15 Jun 2024 10:50
In addition to the previous statements: Pay attention to the wall covering behind the drywall, especially if there are cavities or insulation. The anchors must be installed correctly here; otherwise, the load-bearing capacity loses reliability. Also, make sure to mount the supports perfectly level and check them with a spirit level.
Supilis
16 Jun 2024 07:55
Last feedback from my experience: With the square steel brackets and cavity anchors, the KALLAX remains stable for me even on drywall. Assembly was straightforward, and so far the load capacity has been problem-free.
Just a tip: When screwing the supports, carefully mark the drill holes. Having a second person to hold them makes things much easier.
Thanks for the great support from everyone here!
