ᐅ Placing KALLAX on supports – what do you use?
Created on: 14 Jun 2024 08:37
Supilis
I am currently planning to place my KALLAX shelving unit on supports to make better use of the floor space and possibly create a kind of floating effect. My specific question is: What types of supports or wall mounts do you use to install a KALLAX so that it stands securely but with as little visual weight from floor feet as possible?
I am interested in both materials and fastening methods, especially how you assess potential loads and any tips you have for proper sizing.
Thanks in advance for your practical advice and experiences!
Davidleo
14 Jun 2024 11:34
Hey, I placed squared beech wood blocks underneath and fixed them to the wall, then put the KALLAX on top! It looks really great and holds firmly—I can only recommend it! 🙂 Also perfect if you want something with a vintage look!
SETHBLA
14 Jun 2024 11:52
I use narrow metal beams with multiple holes to allow flexible screw placement. It is important to pay attention to high-quality wall anchors, especially when working with drywall.
Supilis
14 Jun 2024 12:31
Thanks for the initial tips!
@Nabla64, thanks for the detailed guide – step-by-step instructions like that are really helpful. Unfortunately, I only have drywall in the living room, so I'm a bit concerned about the mounting.
Do you have any specific recommendations on which wall anchors would be best to ensure the KALLAX stays securely attached to the wall, even when loaded with books?
Nabla64
14 Jun 2024 13:05
@Supilis Unfortunately, there are only drywall partitions in the living room, so I’m a bit concerned about the mounting.
For drywall, cavity metal anchors (toggle bolts) are recommended. They distribute the load over a larger area behind the wall and hold better than simple plastic anchors. It is important that the anchor is rated for the weight of the KALLAX including its contents.
I recommend using at least two supports per shelf width and installing the anchors exactly according to the manufacturer’s instructions.
SETHBLA
14 Jun 2024 13:28
Nabla64 schrieb:
For drywall partitions, so-called hollow wall anchors (toggle anchors) are recommended.
I can agree with that. For drywall, this is the best choice, especially if your KALLAX is fully loaded. I like to use Fischer hollow wall anchors because they are reliable.
farGlen
14 Jun 2024 14:11
Make sure the beams are at least 40cm (16 inches) deep, otherwise the shelf will tip over easily. When using drywall, choose anchors according to load charts to be on the safe side.
