ᐅ How can I increase the load-bearing capacity of IKEA Hemnes furniture?
Created on: 2 Jun 2021 08:17
nau_jonHello everyone, some time ago I purchased several pieces of furniture from the IKEA Hemnes range, mainly cabinets and dressers. Now I am wondering how I can sustainably increase the load-bearing capacity of this furniture.
I am not only concerned with superficial stability but also want them to remain stable over time under higher loads—such as from placing heavier items or frequent opening and closing.
What measures would you recommend to strengthen the material and construction without compromising the look or functionality? For example, I was thinking about adding internal reinforcements or applying special fasteners.
Does anyone have experience, perhaps with alternative fixings, wood types, or joint techniques that improve load capacity? Are there specific weak points in Hemnes furniture that should be reinforced intentionally?
I look forward to your tips and experiences!
The most critical point with Hemnes furniture is usually the back panel, as it is often secured only with thin nails.
An effective improvement is to attach additional crossbars to the back or to replace the back panel with a 4 to 6 mm (0.16 to 0.24 inch) thick plywood board.
The wood used is often pine, which has clear weaknesses under high load.
For additional stability, it is recommended to reinforce the interior corners with metal brackets, which help distribute the load more evenly onto the supporting elements.
I find this topic really interesting! 😉 Especially with Hemnes, it’s worth reinforcing the insides of the drawers and compartments with strengthened slats or thin profiles made of solid wood. This relieves the structure from pressure when a lot is stored inside.
And yes, the back panel is often the weak point – just a little bit of reinforcement can make the furniture last much longer.
First, a general assessment: Hemnes furniture is designed for household use and typically made from pine wood, that is, solid wood. These pieces feature doweled and glued joints, which are engineered in mass production to handle standard load conditions.
If you want to increase the load capacity, you should especially keep the following points in mind:
- Check that all joints are tight and reglue them if necessary
- Reinforce back panels with additional battens, as the standard thin back panels provide little structural support
- Add metal angle brackets at critical corners
Retrofitting with reinforcements often results in a significant improvement in load capacity, particularly for heavily used furniture such as dressers.
usbla schrieb:
The most critical point with Hemnes furniture is usually the back panel, as it is often fixed only with thin nails.Thanks, that explains a lot. Do you think the back panels should be completely replaced? Or would it be sufficient to simply screw on thin battens across them?
I’m also curious if using stronger screws at the joints (instead of the supplied small chipboard screws) is advisable, or if the material is more likely to split.
