I am currently planning to place my KALLAX shelving unit on supports to make better use of the floor space and possibly create a kind of floating effect. My specific question is: What types of supports or wall mounts do you use to install a KALLAX so that it stands securely but with as little visual weight from floor feet as possible?
I am interested in both materials and fastening methods, especially how you assess potential loads and any tips you have for proper sizing.
Thanks in advance for your practical advice and experiences!
I placed my KALLAX on so-called floating brackets – they give the shelf a really cool floating look! 😊 They are sturdy as well; mine are made of metal, and the difference compared to a traditional floor-standing shelf is really noticeable, especially in terms of appearance. A very elegant and space-saving trick.
Good morning!
Here is a brief guide on how to support a KALLAX unit on brackets:
1. Material selection:
Metal brackets or sturdy wooden battens work well. Metal offers higher load capacity with a more streamlined design.
2. Preparation:
Check the wall condition and choose appropriate wall anchors (also called wall plugs or rawl plugs).
3. Installation:
Screw the brackets horizontally to the wall.
4. Positioning:
Place the KALLAX shelf on the brackets, ideally securing it further with angle braces.
Common mistake: choosing brackets that are too short or using too few fixing points. The weight must be transferred to the wall, otherwise deformation may occur.
Summary:
The mounting process is not technically difficult, but ensure good structural stability and use suitable wall anchors.
2. Preparation:
3. Installation:
4. Positioning:
Summary:
For secure load-bearing capacity, I recommend steel brackets with a minimum material thickness of 3 mm (0.12 inches). The length of the supports should match the depth of the KALLAX (approx. 39-40 cm (15-16 inches)) to optimally carry the load. For a heavy KALLAX, especially with fully loaded compartments, at least three sturdy anchors per support are advisable. Alternatively, specialized wall shelf brackets with an extended projection and screw fixation are also suitable.
