ᐅ How can I securely mount Billy shelves on drywall and plasterboard walls?
Created on: 16 Mar 2023 08:23
mirsatjoHello everyone, I am planning to install several Billy shelves on drywall (gypsum board) walls but have concerns about the stability and safety of the mounting. Since the shelves will sometimes carry heavier loads, I want to avoid the screws pulling out of the wall or damaging the drywall. My question is: What types of anchors or fasteners are best suited for Billy shelves on drywall? Are simple hollow wall anchors sufficient, or should special metal Molly bolts or other fastening solutions be used? Additionally, I am interested in how to best distribute the load and whether it is advisable to secure the shelves further with a wall plate or something similar. Thanks for concrete tips and recommendations!
Use special metal Molly bolts for attaching Billy shelves to drywall partitions. These distribute the load better and can hold more weight than standard hollow wall anchors. Always screw the bolts into the pre-drilled holes of the shelves and make sure they are firmly secured.
Great that you’re taking this topic so seriously! 🙂 For drywall, you can use toggle anchors that expand behind the board and can hold much more weight than simple plastic anchors. I’ve mounted my shelves this way, and they’ve held firmly ever since! Just drill, fold in, and screw – it’s super secure!
Regarding the attachment of Billy shelves to drywall, I would like to provide a brief guide.
1. First, check if there is a wooden or metal stud wall behind the drywall. Attaching directly to the stud with appropriate screws is the most secure method.
2. If there are no studs at the desired shelf location, you should use heavy-duty anchors. Metal Molly bolts are ideal because they fill the cavity well and do not just clamp onto the drywall.
3. Drill the holes precisely to size and avoid oversized holes, as this will prevent the anchor from holding properly.
4. To better distribute the load, it is advisable to mount an additional wooden board on the wall behind the shelf. This can be especially helpful for tall shelves.
Summary: Screwing directly into a stud is always the safest option; otherwise, metal Molly bolts or specialized cavity anchors are the best solution. An additional wall board is useful for heavier loads.
It is very important that the weight is not supported only at a single point on the wall. It may be necessary to secure the Billy shelves to the wall with a batten that is screwed in at several points. This is especially helpful with drywall, as it helps distribute the load more evenly and ensures that nothing tears.
Jensson schrieb:That is exactly right, I did the same. The batten on the wall greatly improves stability. Additionally, it makes it easier to align the shelves.
To distribute the load even better, it is advisable to mount an additional wooden panel on the wall behind the shelf.
