ᐅ Perfectly Aligning Ikea Metod Doors for Quiet Operation
Created on: 1 Apr 2024 09:17
robebe
Hello everyone, I have a specific question about my Ikea Metod kitchen cabinet doors: How can I align the doors perfectly so that they close completely silently and operate smoothly? I have noticed that despite proper installation, there are almost always slight noises when closing. Sometimes a door hangs slightly or swings back, which becomes particularly noticeable during very gentle and quiet opening and closing.
My question is: Which adjustment screws or mechanisms should I optimize? Are there any tips to adjust the doors so that they are play-free and properly aligned in all directions without sticking, but also without rattling? Are there differences depending on whether the hinges are soft-close or not?
I have already tried a few things but am unsure if there is a systematic approach to ensure truly silent and smooth operation, especially over the long term.
U
usbla
3 Apr 2024 07:18
From my point of view, the clicking noise after closing is a vibration caused by elastic deformation of small components. Specifically, it can be related to the door or cabinet body installation, but also to the spring tension in the hinge.
I recommend:
- Check again with a spirit level to ensure all cabinets are perfectly aligned and level.
- If the cabinet bodies are made of chipboard rather than solid wood, the material can slightly expand due to temperature or humidity changes, affecting the tension in the hinges.
- Adjust the hinges in depth gradually, making small changes while carefully observing the effect.
- Optionally, damping strips (such as soft foam or felt) can be attached to the inner sides of the frame to reduce residual vibration noise.
Ultimately, minimizing the noise is a combination of perfect adjustment and the surrounding acoustics.
Nabla64
3 Apr 2024 07:55
usbla schrieb:
Optional damping strips (for example, soft foam or felt) can be glued to the inside of the frame to reduce residual vibrations and noise.
This is a very useful tip!
I have installed felt-like buffers in several Metod kitchens myself, which noticeably reduce the noise without affecting the door’s function. An additional benefit: this padding also protects the finish of the doors.
Important: The buffers should be thin (about 1-2 mm [0.04-0.08 inches]) so that the gap width is not unnecessarily increased and the door still closes softly and completely.
robebe
3 Apr 2024 08:24
Thank you all for the valuable tips and diverse perspectives! To summarize, I will take the following approach:
- Absolutely important sequence: repeatedly go through height, side, and depth adjustments.
- Experiment slightly with the gap width, preferably increasing it minimally.
- Carefully inspect and, if necessary, replace hinges and dampers.
- Lubricate very cautiously and sparingly.
- Use damping or felt strips as additional decoupling.
I will proceed exactly like this in the next few days and report back on whether the doors can then be operated completely quietly and smoothly.
If anyone else has further practical experience with the green soft-close hinges, please share!
