ᐅ New exterior paint has developed cracks
Created on: 20 Jun 2009 19:09
U
Ulfi
Hi everyone,
I had the facade of my house painted by a professional company, using silicone resin paint as stated in the quote.
After the first coat, I noticed many cracks in the paint. It was painted two more times, but without any improvement. Previously, the facade had no cracks.
The facade has many indentations due to the plaster. The paint was applied with a roller.
Now the company says these are just air bubbles and that this does not affect the quality.
I don’t believe that.
What do you think about this?
Ulfi
I’ve attached a photo!
Close-up of a rough plaster wall with texture and cracks
schwarzmeier
3 Jul 2009 14:04
Read carefully, Thommi,
it says "Not less than one meter" !
If you think these are ONLY GUIDELINES, then these RILIS probably don’t matter to you. So where can your evaluation basis be found in writing?
Guidelines are, after all, the basis for evaluation.
But it seems no explanation will help; you apparently believe you are above it all.
Netzer
3 Jul 2009 21:33
I guess it won’t be any different for you, right?
Think again!
No matter how good the wall looks, if a base and topcoat are included in the offer, then that’s how I will do it! I personally stand behind my work with my name, so why should I cut corners on quality? It has never paid off!
schwarzmeier
4 Jul 2009 08:13
@Thommi
What you are accusing colleague Netzer of without even knowing him is quite bold! You are assuming and accusing a master painter of incompetence without knowing him at all—simply outrageous! Unbelievable! Are you serious?
Thommi
4 Jul 2009 13:50
schwarzmeier schrieb:
The accusations you’re making about colleague Netzer without even knowing him are quite bold! You’re assuming that a painting contractor is sloppy work without knowing him at all! Unbelievable! Are you serious?
@schwarzmeier Are you trying to shift the blame onto me just because I brought up a sensitive topic? And because I don’t share your opinion? Let’s keep things reasonable! We all know how things really work. Are painting contractors considered better than journeymen, or why do you emphasize that? I didn’t see anywhere that he is a painting contractor.
schwarzmeier
4 Jul 2009 19:03
"I couldn’t tell that he is a master painter,"
so you can’t accuse Netzer of dishonest conduct! You haven’t raised a sensitive issue here; you just got carried away in a tunnel and now can’t get out. Because you’re afraid of losing face, you’re lashing out in all directions! No matter how wildly you act like Rumpelstiltskin, you’re still on the wrong track! However, you do have the better emojis, and that’s something at least!
Thommi
6 Jul 2009 08:49
That’s why you can’t accuse Netzer of unfair conduct!
You didn’t address a sensitive issue here; instead, you got carried away and now can’t back down. Because you’re afraid of losing face, you’re lashing out all around! No matter how wildly you act like Rumpelstiltskin, you are still on the wrong track!
However, you do have the better emojis, and that’s something after all!
Hello, Schwarzmeier, you’re straying from the main topic!!!!! I think Netzer could defend himself quite well if he wanted to. Or do you think you have a halo? But when you run out of arguments, you have to come up with something else. Why should I have gotten carried away?
I still stand by my previous posts. Where else do thousands of defect reports, court cases, and expert assessments come from every year? Certainly not from properly executed work. Why don’t you make some comments about the appearance of the facade, frost damage caused by moisture in winter, why was the facade repainted for free again, dirt accumulation in the joints? For you, only the guidelines from your Bavarian beer hall buddy apply!!!!! Since you like emojis so much, I made you one more.
