ᐅ My Kallax has small splinters on the edges – is there a risk of injury?
Created on: 9 Nov 2016 08:37
fimobla
fimobla
9 Nov 2016 08:37
I recently purchased a Kallax shelf unit from Ikea, and during assembly and the initial use, I noticed some small wood splinters on a few edges. These splinters are not very large, but they are noticeable, and sometimes you can even feel them slightly when running your hand over the surface.
My main question is: Do these small splinters actually pose a risk of injury? I want to avoid anyone accidentally cutting themselves or getting hurt in any other way.
So far, I haven’t had any serious incidents, but I’m wondering if this is a common issue for this type of furniture and if it’s normal, or if I should consider making a complaint or doing some repairs myself.
Also, I’m interested in any tips on the best way to remove or treat these small splinters without negatively affecting the appearance or stability of the shelf.
Thanks in advance for your help and experiences!
NUGRANT
9 Nov 2016 09:12
Hey fimobla!
That sounds like a minor but annoying issue, but don’t worry – this is actually a common problem with Kallax and similar furniture! Often the wood surfaces are quite sturdy, but small splinters can occur along the edges during manufacturing or transport.
It’s important to remove the splinters, as they can cause small scratches or cuts—especially if you have children or pets at home! 🙂 Usually, sanding or gently smoothing the edges with sandpaper solves the problem quite well. After that, you can apply a protective layer, such as furniture wax or a special varnish, to secure it.
So! Give that a try, it’s really not complicated! And don’t worry, you’re not alone with this issue here! 🙂
Good luck!
Brian
9 Nov 2016 09:46
Hello fimobla,
I completely agree with NUGRANT and would like to explain a bit more in detail.
Kallax is made from particleboard with a melamine coating. The melamine surface is very durable, but on the cut edges where the board is exposed, small splinters can occur if the edges were not finished perfectly or if small areas are damaged due to mechanical impact.
As you correctly suspect, these splinters can cause injuries, especially if touched with fingers or hands. To minimize the risk, I recommend:
1. Lightly sanding the edges with fine sandpaper (grit 120 to 180), which smooths the surface and removes loose splinters.
2. Then treat the edges with a furniture protection product, such as furniture wax or a clear varnish – this seals the surface and prevents further chipping.
If you have not had the shelf for long and the splinters are severe, it is also worth making a complaint to Ikea, as this could be a manufacturing defect.
If you have any further questions about treatment or the complaint process, feel free to ask!
V
valerie-tr
9 Nov 2016 12:05
Exactly, and this is the key to the explanation here: The particleboard itself is relatively soft, and the melamine coating is more like a hard plastic film that is resistant to scratches and liquids. At the cut or joint edges, which are mechanically more stressed, it can happen that either the surface cracks or the wood itself splinters.
If the splinters are only small, the best and most durable solution is to carefully smooth these spots with a fine abrasive pad or 180-220 grit sandpaper. Important: Only sand the edges, not the entire surface, to avoid damaging the melamine coating.
Afterwards, you can treat the sanded edges with a matching edge paint (for example from IKEA or a hardware store) that is specifically designed for furniture edges. This seals the area and prevents further cracking.
One more tip: For Kallax, which has quite visible edges, it can also help to install a small edge protector in the form of plastic profiles or edge strips – this is especially useful if there are children in the household, as the edges become smoother and safer.
I would be interested to know how visible and large the splinters are? And does the problem occur in multiple places?
fimobla
10 Nov 2016 07:45
valerie-tr schrieb:
I’m curious about how visible and large the splinters are? And does the problem occur in multiple places?
Thanks for the detailed response! The splinters are actually quite small, mostly just a few millimeters (about 0.1 inches), but they can definitely be felt. There aren’t many, but some corners and edges have more than others. Some edges are completely smooth, but on others you can feel the rough spot or the tiny chip. In daily use, they’re not constantly a problem, but I don’t want to underestimate it, which is why I’m asking here.
Yesterday, I lightly sanded the areas with fine-grit sandpaper—and yes, the result is noticeably better. I’m thinking of applying edge lacquer or wax next; that’s actually a really good idea.
One thing I’m still wondering: Should the splinters be treated as soon as possible, or is it okay to wait a bit to see if more come off or if it gets worse with regular use, like normal loading and unloading?
Henry
11 Nov 2016 10:26
fimobla schrieb:
Should splinters be treated as soon as possible or can you wait a bit?
Hi fimobla,
I wanted to respond thoughtfully to your situation. Your caution is completely understandable—furniture with edges that can cause injury can naturally be unsettling. I had a very similar issue with a shelf that had splinters on the edges, and I ignored it for too long. The result for me was quite a hassle because the wood kept splitting further over time, and I ended up having much more repair work.
So my advice is to address it promptly, even if the splinters are small. The stress on the edges from normal use—loading, unloading, bumping—often increases over time, which can cause the material to detach further.
Aside from that, I think it’s great that you’re taking this seriously and focusing on safety. It’s especially important when children or guests are around.
So: treat, smooth, protect—and then you can use the shelf with peace of mind. 🙂
