ᐅ My KALLAX unit creaks even more than before after tightening the screws?
Created on: 7 Feb 2021 08:37
Pochen
I have an issue with my KALLAX shelving unit from IKEA: After reassembling it (I completely took it apart and rebuilt it to make it more stable), it now creaks much louder in several spots than before. It makes really unpleasant noises as soon as it is moved even slightly or when light pressure is applied. Before the reassembly, it wasn’t completely silent either, but it was noticeably better.
I followed the instructions carefully and checked everything several times; the screws are tightened properly. Still, the creaking has gotten worse. Has anyone experienced something similar or have tips on how to identify and fix the problem? Maybe the material or certain components play a role?
I would really appreciate a collection of ideas, possible causes, or proven solutions, as I would like the shelving unit to be quiet and sturdy. Thanks in advance!
Pochen
7 Feb 2021 12:20
RENMA schrieb:
Squeaking noises are caused by friction between building components, often due to excessive point pressure.
Thanks, that makes sense! I notice the noise often comes from where the side panels and baseboards meet—maybe some kind of tension or unevenness that has increased.
The surface is a wooden floor but with felt pads. I will measure the flatness and deliberately loosen and then retighten individual screws evenly.
I’ll keep you updated.
rimole
7 Feb 2021 13:07
Be careful when tightening screws: sometimes excessive force can make the material brittle and cause creaking. Tighten loosely, test, and adjust as needed.
Alternatively, slightly shift the position to reduce tension.
Pochen
8 Feb 2021 07:45
Update from my side:
Today, I changed the stacking order of the screws, placing them opposite each other as suggested, and applied some furniture wax to the contact points.
The creaking has become noticeably quieter, but it is unfortunately not completely gone yet. It is also much more subtle, so maybe it's a step in the right direction?
I might also try washers or different types of felt pads under the feet later. Thanks for the help so far!
KLONA
8 Feb 2021 10:29
If creaking continues despite thorough screw checks and maintenance wax, it is often due to the material properties of the particleboard used in KALLAX.
Consider decoupling the connection points with thin felt tape or foam rubber. This significantly reduces friction and noise.
Additionally, occasionally retightening the screws after the initial period of use can help, as the wood may settle slightly.
Pochen
9 Feb 2021 08:53
KLONA schrieb:
Consider decoupling the connection points using thin felt tape or foam rubber.
That’s a good tip, thank you! I’ll give it a try, especially since it also helps with soundproofing to some extent.
I realize the issue is quite complex because it’s not just about tightening screws—the interaction between the materials is crucial. Thanks to everyone for the many helpful suggestions – they really help me approach the problem constructively.
