ᐅ Malm Nightstand Stains on Wood – How Can I Remove Them?
Created on: 20 Feb 2023 07:38
farmar
farmar
20 Feb 2023 07:38
I have a Malm nightstand made of light wood at home, which unfortunately has developed some stains. These are typical signs of wear, including water and possibly grease stains, which in my opinion have caused superficial damage to the wood’s finish. My specific question is: How can I clean or remove these stains without damaging or roughening the surface of the nightstand? Are there any proven home remedies or special products that work best for this type of light wood furniture? I would appreciate tips that are effective but also gentle, as I want to preserve the original finish as much as possible.
NoValentin
20 Feb 2023 10:42
For water stains on a Malm nightstand, a soft cloth with some toothpaste (not gel type) often helps. Gently rub it in, then wipe off with a damp cloth. For grease stains, you can usually remove them with a little dish soap on a damp cloth. Important: Never rub hard, as this can damage the finish.
Wesley
21 Feb 2023 16:19
NoValentin schrieb:
You can usually remove grease stains with a bit of dish soap on a damp cloth.
That works great! Additionally, you can do a favor for the Malm bedside table by applying a small amount of olive oil on a cloth, which also refreshes the wood finish. Just apply very sparingly, let it absorb, then polish with a dry cloth. This makes stains less noticeable and the surface shines again. 🙂
It’s important to do this carefully to avoid adding too much oil or moisture, as that can leave a sticky residue. Always start with a small amount.
gesar32
21 Feb 2023 18:03
To clean stains on painted or veneered wood, like on a Malm nightstand, without causing damage, I recommend the following step-by-step approach:
1. First, try using mild soapy water and a soft cloth to remove surface dirt.
2. For water stains, gently rub a small amount of toothpaste (white paste without gel).
3. Grease stains can often be removed by lightly rubbing with dish soap on a damp cloth.
4. For stubborn stains, you can use special cleaning and care products designed for wood surfaces, which are commercially available.
Important: Always test each step first in an inconspicuous area! Aggressive scrubbing or using harsh chemicals often causes noticeable damage to the finish, which can be costly to repair.
