ismaillis2 Jun 2022 10:17Hello everyone, I have a Malm chest of drawers from Ikea, whose white surface is peeling or losing paint in some areas. I would like to repaint it to refresh its appearance and prevent further damage. My question is: what is the best way to prepare the surface, which type of paint and brush are most suitable for this purpose, and are there any specific techniques I should follow to ensure the result is as durable as possible? I appreciate any tips and personal experiences!
ismaillis schrieb:
How should I best prepare the surface, and which paint and brush are most suitable for this purpose?I honestly think it’s a bit crazy that people feel the need to repaint such a simple piece of furniture like the Malm dresser. Let’s be honest, Ikea furniture is more like disposable products. But if you want to hold on to it: The best approach is to sand the areas thoroughly so the new paint will adhere properly. I would definitely recommend priming first. Instead of using emulsion paint, it’s better to use acrylic or satin wood lacquer. Brush? I’d suggest a small foam roller for a smooth, even finish.
I find rebufar’s approach understandable but would like to add some details. For preparation, fine sandpaper (grit 220) is ideal to smooth out old chips. Afterwards, the dresser should be cleaned with a damp cloth to remove the sanding dust. For painting, I recommend a special furniture or acrylic paint suitable for MDF surfaces. Both a synthetic-bristle brush and a foam roller work well; the important thing is to apply thin coats and allow them to dry properly to achieve a durable finish.
I’ll add a brief step-by-step guide that will hopefully help you:
1. Roughen damaged areas with fine sandpaper (around 180-220 grit) and remove any loose paint residues.
2. Thoroughly dust off the surface and, if needed, wipe it with a slightly damp cloth.
3. Prime: Use a suitable adhesion primer for MDF and wood to improve paint adhesion.
4. Sand lightly again after the primer has dried.
5. Final coat: Use a white acrylic or polyurethane paint designed specifically for furniture.
6. Apply several thin layers, as thick layers tend to peel off more easily.
7. Follow drying times carefully and ideally paint in a dust-free environment.
Important: Avoid pressing too hard with the brush to minimize visible brush marks. Good luck!
Great topic! 🙂 I had exactly the same issue with my Malm chest of drawers and was really surprised how much you can achieve with a bit of effort. Instead of a regular brush, I even tried a small paintbrush and a foam layer – the result turned out very smooth. Tip: It’s also important to allow some time between coats. Letting it dry for a day definitely makes a difference! After that, the surface not only feels smooth but also looks almost like new. Good luck, you can do it!
LOJOPAR schrieb:
Priming: A primer suitable for MDF and wood ensures better paint adhesion.I find this point extremely important! I have noticed that many people skip priming and then complain about paint chipping later. I also think it’s practical to test the surface of the dresser in an inconspicuous spot before painting to make sure the paint and primer are compatible. I was a bit uncertain myself at first, but with patience, it works!
