ᐅ Making Replacement Parts for BILLY Shelves Yourself – Is It Possible?
Created on: 14 Feb 2022 09:23
LAUSEBASTI
I have had an IKEA Billy bookshelf for some time now, which I actually like very much. Unfortunately, one of the shelves’ fastenings broke, so I can no longer install it securely. Since IKEA often offers only limited options for individual replacement parts and I don’t want to replace the entire unit in my case, I’m wondering if it is possible to produce replacement parts for the Billy bookshelf myself?
I am particularly interested in whether replacement shelves or small accessories like the pin strips for shelf support can be made with simple means – for example, with some DIY skills, suitable materials, or even 3D printing.
Does anyone here have experience with this? Or are there any tips on how to repair the bookshelf cost-effectively and functionally without relying on original replacement parts?
I look forward to your opinions and suggestions!
V
Vinlen
15 Feb 2022 08:46
The construction of BILLY is relatively simple, so replacement parts can be made quite accurately based on the measurements.
However, custom-made parts will never fully match the original quality. Especially the perforated strips are very precise and durable due to plastic injection molding.
If you use wooden replacement shelves, make sure to pay close attention to the exact drilling depth and thickness of the board, otherwise the shelf won’t fit correctly.
A tip: First create a prototype from inexpensive material to test the fit.
koneo
15 Feb 2022 11:29
nedagla schrieb:
I have a friend who got one of those 3D printer boxes and he has already reprinted some small Ikea plastic parts
Sounds great! I would just make sure that the 3D printing material is strong enough.
PLA, for example, tends to be brittle, while PETG or ABS might be better options.
If the parts are load-bearing or subject to continuous stress, post-processing or coating can help extend their durability.
Also important: the 3D models need to be very precise, otherwise the fittings won’t hold properly.
PAUREO54
16 Feb 2022 07:51
It is possible to make replacement parts for BILLY yourself, but only if you work precisely.
MDF or particleboard are the best choices for shelves.
Plastic parts for the perforated strips are more difficult; here, either 3D printing helps or you buy original replacement parts.
Pay close attention to exact measurements!
kemads46
16 Feb 2022 09:16
LAUSEBASTI schrieb:
Is it possible to make replacement parts for the BILLY shelf myself?
Yes, you can! To summarize:
- Replacement shelves: yes, using wood-based materials like MDF or particleboard with a thickness of 16 mm (5/8 inch), custom-made with the correct dimensions and drilled holes.
- Peg strips and small plastic parts: 3D printing or buying second-hand is recommended, as making these yourself can be labor-intensive.
- Time spent and material costs should be weighed against buying new original parts or complete new units.
Conclusion: DIY is feasible, especially with woodworking. Only for the plastic parts is the effort higher.
