ᐅ Which Billy models have particularly sturdy back panels?
Created on: 24 Mar 2016 08:13
Arjan
I would like to start a discussion with the question: Which Billy models from Ikea have especially sturdy back panels?
I have noticed that in some versions the back panels seem quite thin and unstable, which can lead to warping or damage over time. I am looking for a model that has a significantly more robust back panel—preferably with thicker material or better construction, ideally without requiring expensive modifications.
Perhaps someone has experience with different versions or alternatives that remain stable under load. I am interested both in official product types and insider tips for particularly strong back panels.
Leland
25 Mar 2016 08:12
Arjan schrieb:
I am primarily looking for a sturdy back panel for open Billy models that are not supplied with doors or glass
In this case, the version with an MDF back panel in the wider 40cm (16 inches) shelves is the best. These are significantly more durable than the thin fiberboard panels used in the narrower models.
Additionally, the back panels of the 40cm (16 inches) versions are often finished with warmer paint or foil, which also contributes to their stability.
barda6
25 Mar 2016 08:58
If an open design is planned, also consider whether the back panel is planed or coated. This affects stability during installation.
For added security, you can install a thin plywood board, which remains invisible if fitted seamlessly.
NICOLELIS
25 Mar 2016 09:34
For stability, the Billy 40x28 cm (16x11 inches) model with an MDF back panel, without doors, is recommended. It holds up much better than all the narrower versions.
ritotar
25 Mar 2016 10:05
Especially for transport: If you plan to move the shelf frequently, it’s worth choosing models with braces and a thicker back panel. This helps prevent the notorious creaking and warping.
I have seen shelves that hardly returned to their original shape after being relocated – definitely not fun.
LuMarcel43
25 Mar 2016 10:46
Another idea: Would it ultimately help to install vertical strips on the inside of the back panel of an open Billy-style shelving unit? Basically, to increase stability and prevent warping.
This is a retrofit solution, but it could be a good compromise without having to replace the entire back panel.
CHENNE
25 Mar 2016 11:21
LuMarcel43 schrieb:
side strips installed... to prevent warping
This works quite well in practice. Additional side braces significantly improve lateral stability. Combined with an MDF back panel, this creates a very sturdy solution.
For open shelves, I also recommend using screws instead of nails for attaching the back panel – this reduces movement and wobbling.
