ᐅ KALLAX became unstable after moving it to the attic – how to stabilize it?
Created on: 23 Dec 2024 09:17
Nonben59
I recently moved my KALLAX shelving unit and transported it to the attic. Now it is noticeably more wobbly than before, even though I assembled it exactly the same way. The floor is somewhat uneven, and the attic itself is not as stable as the previous room.
My question to the community: How can I stabilize my KALLAX shelving unit so that it stands securely in the attic and no longer wobbles? Are there specific techniques or materials that work well for fixing the unit in place? Are there differences in stability depending on whether the unit is positioned vertically or horizontally?
I appreciate any tips, and I’m also interested in hearing about your experiences with stabilizing a KALLAX shelving unit on uneven surfaces. Thanks in advance!
koduga
24 Dec 2024 09:47
I can imagine how frustrating it is when a shelf suddenly wobbles, even though you did everything “right.” Attics are often older or uneven spaces where you just have to work with some improvisation.
Have you tried securing the shelf with ratchet straps or something similar when wall mounting isn’t possible at the moment? That’s how I managed to stabilize the wobbling temporarily.
Sometimes adding some weight to the shelf helps, too – this reduces rocking if the base spacing on the floor isn’t ideal.
Chin up, you’ll definitely find a practical solution! 🙂
Kinbu
24 Dec 2024 11:04
Hello Nonben59,
I just want to add that the problem does not have to be caused only by unevenness in the floor. It is also a good idea to check whether all the connections are properly secured – over time, screws or wall plugs can sometimes loosen.
If your KALLAX shelf is free-standing, securing it to the wall is indeed one of the most effective solutions, as already mentioned. In this case, choosing the correct mounting height helps prevent the shelf from rubbing against or being stressed by the slope.
If you like, I can give you advice on which screws and wall plugs work best for attaching items in an attic – often the walls are not traditionally brick, but made of drywall with a wooden stud frame.
Good luck!
Paunon
25 Dec 2024 10:59
Adjustable feet plus wall anchors = stable solution.
Wooden wedges or plastic stoppers effectively compensate for minor unevenness.
Nonben59
25 Dec 2024 15:13
Dilen schrieb:
How uneven is your attic floor exactly?
The floor covering consists of old wooden floorboards, which are uneven by about 0.5 to 1 cm (0.2 to 0.4 inches) in some areas.
Filippo schrieb:
Is the shelf placed directly against the sloped ceiling or more centered on the floor?
It is positioned very close to the sloped ceiling, but the area behind it is only covered with drywall, not a load-bearing wall.
Thanks to everyone—I’m keeping the suggestions about adjustable feet and a stronger back panel in mind. Fixing it to the wall sounds secure but is a bit tricky in the attic because of the slope and, as mentioned, there’s only drywall behind the shelf.
I will probably try working with wedges and adjustable feet and reinforce the back panel if needed.
Jensson
26 Dec 2024 08:22
Nonben59 schrieb:
Wall mounting sounds secure, but it can be a bit tricky in the attic because of the slope, and as mentioned, there is mostly drywall behind the shelf.
This is important information. You should avoid using anchors directly in drywall. It’s better, if possible, to secure into the wooden studs behind it. An electronic stud finder can be very helpful here. Alternatively, furniture anchors with long screws that reach the frame are a safe option.
Additionally, reinforcing the back of the shelf with a thicker panel is very effective in preventing it from tipping. I also recommend fastening the panel at the top and bottom with brackets.
Also, try checking if the shelf becomes more stable by placing a small rubber mat or a firm felt pad under the shortest legs; this can help quickly.
Good luck!
