I recently received a KALLAX shelf from IKEA, but it has been leaning since delivery. It was carefully packaged and shows no obvious visible damage, but when I set it up, it doesn't stand straight and wobbles slightly. I have already checked that all screws are tight and the shelves are properly in place. The wall is straight, so I think the problem is with the shelf itself.
Has anyone had experience with this and can suggest what to do in such a case? Is it possible to adjust or repair the shelf, or would it be better to exchange it? Are there special leveling feet or tricks to correct uneven stability?
Thanks for your advice!
RonJarrett schrieb:
With IKEA shelves, it is advisable not to neglect wall mounting.This is a very important point. Most of these shelves are designed for wall mounting, precisely to avoid wobbling. It is recommended to secure the shelf to the wall using the provided screws and wall plugs. This significantly prevents tipping or wobbling, especially on laminate or hardwood floors.
Also, have you already checked whether all the connecting boards and screws along the front and side edges are properly fitted? Sometimes, moving the shelf slightly shifts its position, which can cause misalignment. If needed, disassembling the shelf completely and carefully reassembling it can help.
If the shelf is unevenly loaded (heavy items placed only in one corner), this can also cause it to tilt.
Was the shelf unstable after assembly or immediately after transport? This can help better understand the cause.
