ᐅ KALLAX shelf arrived crooked after transport – what to do?
Created on: 12 Aug 2020 10:03
Kanar
Kanar
12 Aug 2020 10:03
I recently received a KALLAX shelf from IKEA, but it has been leaning since delivery. It was carefully packaged and shows no obvious visible damage, but when I set it up, it doesn't stand straight and wobbles slightly. I have already checked that all screws are tight and the shelves are properly in place. The wall is straight, so I think the problem is with the shelf itself.
Has anyone had experience with this and can suggest what to do in such a case? Is it possible to adjust or repair the shelf, or would it be better to exchange it? Are there special leveling feet or tricks to correct uneven stability?
Thanks for your advice!
LIELCHEN
12 Aug 2020 10:27
Kanar schrieb:
since transport crooked[...] does not stand straight and wobbles slightly
Isn't that usually an issue with cheap materials? I mean, KALLAX is basically IKEA standard, but I wonder if it might just be a faulty unit. Either a warped board or distorted parts. Maybe the problem is that the focus is too much on attaching it to the wall and not enough on the floor. Have you checked if the floor is absolutely level?
In my opinion, people tend to assume a manufacturing defect too quickly, but it’s often a combination of packaging, assembly, and the environment. Did you assemble the unit yourself completely, or did you receive it from IKEA pre-assembled? That can also make a difference.
RETRAVIS
12 Aug 2020 10:45
The KALLAX shelving unit uses simple particleboard with a melamine coating. These materials often do not withstand moisture and heavy stress during transport very well. Warped or slightly deformed back panels can indeed affect the stability.
First, I recommend thoroughly checking the supporting surfaces, for example by using a spirit level to measure the floor. If the shelving unit itself is slightly uneven, adjustable furniture or leveling feet can be added. These are available at most hardware stores and can usually be easily mounted on the bottom of the feet.
To justify an exchange, there would need to be a clear material defect. Small tolerances are normal with this type of furniture.
INGRID34
12 Aug 2020 11:08
What helped me was simply sticking felt pads or small washers under one of the feet. This way, unevenness in the floor is compensated. Also, gently retightening all the screws often improves stability.
Ernesto
12 Aug 2020 11:35
Kanar schrieb:
it is not perfectly straight and wobbles slightly
To systematically analyze the problem, you should follow these steps:
1. Place the shelf on a hard, level surface, ideally checked with a proper spirit level. Check all sides, including each shelf, for flatness.
2. Inspect every connecting screw: Some of these shelves use dowels together with screws – if dowels are not fully seated or screws are only hand-tight, this can affect the structure.
3. Measure the back panel: Is it flat and securely screwed? The back panel contributes significantly to stability.
4. The legs or feet: If these are simply cut, tensions can occur after transport. As RETRAVIS already mentioned, adjustable furniture feet or suitable pads can help here.
If all parts are flat and secure yet there is still leaning or wobbling, there may indeed be a material defect – in that case, I recommend filing a complaint with the retailer.
Can you also specify the type of surface the shelf is standing on? Carpet, tile, wooden floorboards? This can make a difference.
RonJarrett
13 Aug 2020 09:12
If there are no obvious damages or warped components, wobbling is often caused by uneven floors or missing leveling feet.
For IKEA shelves, it is advisable not to neglect wall mounting. The KALLAX shelf has corresponding holes and a suitable bracket for this purpose. This significantly improves stability and increases safety.
An exchange is usually only reasonable if there are cracks, breaks, or severely warped parts. Minor unevenness can generally be compensated with washers or furniture glides.
