ᐅ KALLAX shelf has a strong solvent smell – how can I properly air it out?
Created on: 3 Feb 2021 17:04
Rujuti
Hello everyone, I recently bought a Kallax shelf unit from IKEA, and when unpacking it, I noticed a fairly strong smell of solvents. Does anyone have experience with the best and, above all, safest way to air out a piece of furniture like this? I want to avoid the chemical odor lingering for a long time in the home or potentially causing any health issues. Are there any recommended methods or special tips to counteract the off-gassing using simple means? Thank you in advance!
Karsten45
4 Feb 2021 13:16
The solvent smell from new furniture like KALLAX is unfortunately a common issue. My tip: simply put on your favorite playlist on Spotify for a while, open the window, and turn on the fan – this way, the shelf can air out in good company :-)
Jokes aside, I’ve had good experience leaving furniture unused in a well-ventilated area initially. The smell really does fade, and if it doesn’t, at least you’ll have the satisfaction of knowing you did everything right.
Daledra
5 Feb 2021 10:08
For additional odor neutralization, you can also place a bowl of vinegar near the shelf. Vinegar vapor binds certain volatile substances and can help reduce the smell.
Rujuti
5 Feb 2021 11:14
PRA64 schrieb:
In my experience, placing small bowls with baking soda or activated charcoal nearby can help, as they absorb odors.
Thank you very much for the tips! I find the suggestion to wipe the back surfaces with a damp cloth very helpful – I hadn’t thought of that.
Also, I really like the idea of using baking soda. Can I place it directly inside the shelves, or is it better to put it only around the outside? How long should these odor absorbers be left in place?
noge58
6 Feb 2021 14:32
Rujuti schrieb:
Can I place it directly inside the shelf compartments, or is it better to put it only around the outside?
Hey, of course you can put baking soda inside the compartments, preferably distributed in small bowls or bags! 🙂
I did this in my shelving unit once, and within a week the unpleasant odor was noticeably reduced. Just make sure to ventilate regularly and replace the baking soda when its effectiveness decreases. You’ve got this!
