ᐅ Painting Kallax with spray paint – winner of tests – any experiences?
Created on: 4 Dec 2021 08:23
Narjonatho
I am currently considering repainting my Kallax shelf with spray paint because after several years I no longer like the color and some spots have chipped. It is especially important to me to use a paint that provides a smooth, even surface after drying and is as durable as possible.
My question for you: which spray paints have you found to be the best for repainting Kallax shelves? Which brands or types deliver the best results regarding coverage, durability, and application?
I would also like to know if you use any special surface preparations to improve paint adhesion, and whether it makes a difference to disassemble the shelf completely or paint it fully assembled.
I look forward to your experiences and tips!
flota
4 Dec 2021 12:30
In my experience, primer is the key to a long-lasting finish, especially on surfaces like Kallax, which is usually made of melamine-coated particleboard. Without a bonding agent, the paint will peel off quickly.
Regarding spray paint: Most pure acrylic sprays dry quickly but are not always durable enough. Synthetic resin-based sprays offer better durability but require longer drying times.
My recommendation: Sand the surface, apply a bonding agent, use thin coats of synthetic resin spray paint, and allow 24–48 hours drying time. Undercoating or rust protection sprays are unnecessary for indoor furniture.
GALEO4
4 Dec 2021 13:01
Joe52 schrieb:
Clearly naming Montana Gold as the test winner,
I can’t agree with that. Montana Gold is indeed great, but it’s extremely expensive and often overrated. For the average DIYer, Tesa spray lacquer or Dupli-Color usually works perfectly fine.
Also, the idea of spraying a Kallax on such a large surface isn’t ideal – in my opinion, using a brush and roller paint gives a more high-quality finish and is less unpredictable.
You’re overlooking the craftsmanship involved. The “test winner” is a myth; every user needs to experiment for themselves. For the “Kallax” project, that’s too much of a simplification.
LIELCHEN
4 Dec 2021 15:27
GALEO4 schrieb:
The "test winner" is a myth, every user has to try it themselves.
Finally, someone says this with a bit more perspective. Too often, we just act like consumption zombies who believe that everything is perfect if it’s a test winner.
Even if the “test winner paint” has the best specifications, if you apply it incorrectly, it won’t work.
Good advice: Always start with a test on a small area. And for those who enjoy DIY, consider using appropriate painting kits (brush, roller, clear coat) instead of relying solely on spray cans.
KNUTGI
5 Dec 2021 08:11
Hello! 😄
I want to share my experience since I recently went through this topic myself. Briefly: I used Belton spray for my Kallax (not advertising, but it’s very reliable).
In my opinion, the most important thing is patience. Spraying takes time. It’s better to apply several thin layers and let each one dry thoroughly in between. And definitely mask everything carefully or do it outside, otherwise you’ll end up with paint everywhere ;-)
Also: I dismantled the shelf because that way you can reach the edges much better and avoid unpleasant drips. And yes, I had to sand it; otherwise the paint won’t adhere well.
So the conclusion: no matter which top-rated product you choose, spray carefully and take your time. Otherwise, you’ll regret it. Good luck!
Elias
5 Dec 2021 08:47
KNUTGI schrieb:
I took the shelf apart because that way you can reach the edges much better and avoid weird protrusions.
What do you mean by "weird protrusions"? Sounds interesting!
I really like reading that many people here pay great attention to preparation. No one had told me before how important sanding is. I really want to do it carefully now to avoid any unpleasant surprises.
KNUTGI
5 Dec 2021 09:04
Elias schrieb:
What do you mean by "weird drips"?
By that, I mean the small paint buildups that form along edges or corners when spraying, caused by the paint being too thick or drying too quickly in some spots. They look like tiny "paint drops." This often happens when the entire piece of furniture is painted at once and either the sprayer is too far away or too much paint is applied at one time.
Working on individual boards allows for cleaner application and results in a smoother, more even surface. 🙂
