ᐅ Kallax Warped After Moving – Is Return Possible?
Created on: 21 Jun 2017 17:13
FEGUJON
FEGUJON
21 Jun 2017 17:13
I recently unpacked my IKEA Kallax shelf after a move and noticed that it has warped slightly, so it no longer maintains its exact original shape. My main question is: Is it possible to return or exchange a Kallax shelf at IKEA due to such deformation, which was obviously caused by the move?
I have used the shelf for about a year, and it was only used sparingly and with care. Although the warping does not dramatically affect stability, it does significantly affect the appearance, so I am unsure whether I have any right to return it.
Has anyone had experience with such cases at IKEA? How accommodating are they, especially when the shape has been affected during transport?
Thank you very much for your insights and help!
Gerard
21 Jun 2017 18:26
FEGUJON schrieb:
Is it possible to return or exchange a Kallax shelf at IKEA due to a deformation like this, which was obviously caused by moving?
IKEA generally has a return period of 365 days, as long as the item is undamaged and complete.
In your case, since the deformation happened during the move, goodwill for a return might be limited, because damage caused by transport after purchase is often not considered a manufacturer defect.
I recommend documenting the damage with photos and presenting them at your nearest IKEA store, then contacting customer service. They are often accommodating if the defects are clearly visible and the item otherwise looks brand new. However, there is no warranty on dimensional stability since the Kallax is made from assembled wood chipboard panels; these can react to moisture and mechanical stress.
An exchange could also be possible if you return the shelf with a proof of purchase and only minor signs of use, but the cause of the deformation might cause difficulties here.
Alternatively, you might try light corrective measures to fix the deformation—targeted adjustments often help.
If you have further questions, I can also check the exact return conditions with IKEA customer service.
Noahlu
22 Jun 2017 09:57
Gerard schrieb:
Damage caused during transport after purchase is often not considered a manufacturing defect.
This assessment definitely applies to the specific material of Kallax. Kallax is mostly made of MDF panels with a decorative foil. Once the furniture is under tension or exposed to moisture, it easily deforms, and these deformations do not always fully revert afterwards.
FEGUJON schrieb:
The deformation doesn't dramatically affect stability, but it is visually quite noticeable
If the functionality is not impaired, returning the item is usually difficult, as IKEA rarely accepts returns for damage caused by use. The standard 365-day return policy generally applies only to unopened or like-new items.
For a move, I recommend the following step-by-step process if you still want to try exchanging the shelf:
1. Have the original receipt ready
2. Dismantle the furniture and check for stability
3. Take photos of the deformation, especially close-ups
4. Contact the IKEA store by phone or email and explain the situation
5. Hope for goodwill, as moving-related damage is often not covered
If that doesn’t work, you can at least try to repair the shelf by laying it flat on an even surface and applying light pressure or using heavy books to help restore its shape. Sometimes storing it in a dry room for several weeks also helps the material settle.
One important detail: Please check if the furniture might have been damaged by moisture, as such deformations are often caused or worsened by water or high humidity.
tuFernando
22 Jun 2017 19:44
Noahlu schrieb:
If it doesn’t affect the functionality, returning the item is usually difficult
That is probably true, but I think it’s a shame if you don’t at least get a chance for goodwill. Moving is often stressful, and such damage can easily happen even if you’ve been careful.
FEGUJON schrieb:
Has anyone here had experience with cases like this at IKEA? How flexible are they, especially if the shape was affected during transport?
I once had a case where a piece of furniture showed small dents after transport. IKEA advised me to show the damage directly in the store and look for a solution. They didn’t offer a full exchange, but I was able to get a discount on a new item.
My advice to you: definitely try going straight to the store and explain your situation honestly. Even if there is probably no warranty on the material, customer service staff often try to offer a solution – especially if you stay polite and factual.
In the worst case, you keep the shelf, but trying won’t hurt. Good luck! 🙂
fepau
23 Jun 2017 08:11
Hey FEGUJON,
tuFernando schrieb:
Fingers crossed for you! 🙂
Exactly, don’t give up! 🙂 When IKEA wants to make a good impression, they sometimes show real goodwill.
Those Kallax shelves are very practical, but unfortunately prone to warping during transport because the material isn’t solid wood. Maybe you’ll get lucky and they’ll replace the shelf or at least offer you some compensation.
If not, try laying it flat or carefully weighting it down if the deformation isn’t too severe. Sometimes the wood “recovers” that way!
I once had transport damage too, but with some patience and “training,” the furniture straightened out pretty well. That was a real success!
Good luck and keep us updated! :-)
