ᐅ KALLAX doors rattle when music is playing – is there a way to soundproof them?
Created on: 2 Mar 2020 08:37
baudeo
baudeo
2 Mar 2020 08:37
Hello everyone, I have a specific problem with my IKEA KALLAX shelf, more precisely with the doors I attached to it. When I play music through speakers in the room, the doors produce a slight rattling sound repeatedly – especially with bass-heavy songs. The noise is caused by slight vibrations, apparently transmitted by the sound waves. Now I’m wondering if anyone has experience with this and if there is an effective way to dampen or reduce the rattling of the doors? What methods or materials would be suitable for this without affecting the appearance or functionality of the shelf? I would really appreciate concrete tips or product recommendations!
jelite
2 Mar 2020 09:24
Hello baudeo, your issue with the rattling KALLAX doors when playing music sounds like a typical case of resonance and vibration transmission. To reduce this, I recommend a three-step approach: 1. Inspect the contact points – The doors should fit as firmly and vibration-free as possible. Small gaps often cause rattling. 2. Use damping materials – To minimize it, you can apply self-adhesive felt pads or thin rubber strips to the door frames where the doors meet the shelving unit. This reduces the hard contact that causes the rattling. 3. Check the interior load – If the doors are heavy (for example, due to stored items), vibrations can be amplified. Lightweight padding or removing heavy objects can help here. I suggest testing the pads first in an inconspicuous area. Important: Use materials that do not leave marks or adhesive residues to preserve the appearance. In summary: cushion laminate door stops with felt or rubber, adjust the doors to fit firmly, and reduce the internal weight. If you need more details, I’m happy to help!
Bagupo
2 Mar 2020 09:52
Attach felt pads to the hinges or the door frames, as this usually provides effective noise dampening. Also, check if the doors are still properly aligned; movement plus vibration equals rattling.
plo60
2 Mar 2020 18:46
The phenomenon is actually a mechanical coupling of speaker vibrations through the air and furniture. However, I wonder: Isn’t the rattling also a sign of installation with too large tolerances or hinges that are too tight, which transfer vibrations?
Bagupo schrieb:
Attach felt pads to the hinges or door frames; this usually dampens the noise effectively.
Good idea, but it doesn’t address the possible vibration transmission directly at the shelving unit. Have you tried decoupling the shelving unit or at least the doors from the floor or surface? For example, small rubber buffers under the cabinet or even a thin layer of insulation material between the wall and the shelf? This could reduce the energy transfer. I’m interested to know if the problem also occurs with quieter music or only at high bass levels.
jelite
3 Mar 2020 07:19
plo60 schrieb:
However, I wonder: Isn’t the rattling also a symptom of installation with too large tolerances or hinges that are too tight, transmitting vibrations?
Good observation. If the door hinges are too tight, this can indeed cause unwanted transmission through the frame. I would recommend carefully adjusting the hinges, if possible loosening them slightly, and then adding damping afterward.
baudeo schrieb:
Which methods or materials would be suitable for this without affecting the appearance or functionality of the shelving unit?
Functionality should be maintained, so thin felt or silicone pads are ideal since they are barely visible and do not add bulk. For internal doors, a thin foam or cork insert on the back of the door can help reduce vibrations. It is important to balance damping with load-bearing capacity.
In addition, in extreme cases, special antivibration mats can be placed on the floor to reduce resonance in the room.
