ᐅ KALLAX converted into a dollhouse – Is the stability sufficient?
Created on: 23 Mar 2018 18:43
LAGAU
LAGAU
23 Mar 2018 18:43
I am currently working on converting an IKEA KALLAX shelving unit into a dollhouse. My main question is: Is the stability and sturdiness of the modified unit sufficient to be safely used as a dollhouse for children? I want to avoid any risk of the unit tipping over or parts coming loose due to shifts in weight or normal play.
The conversion will also involve adding interior walls, several floors, and possibly some kind of roof. Does anyone have experience with the load-bearing capacity of the KALLAX and know if additional reinforcements are necessary? How stable is the shelving unit in everyday use when repurposed as a walk-in dollhouse?
If anyone has tips on how to improve stability or knows common weak points to watch out for, I would greatly appreciate your feedback.
nedagla
23 Mar 2018 19:14
Oh, that sounds really exciting! 😊 I’ve heard that the KALLAX is quite sturdy—mainly because it’s made from particleboard with a foil coating. But if you’re adding interior walls and a roof, I would definitely reinforce the joints to be sure. For example, using screws and corner braces!
LAGAU schrieb:
Is the stability and strength of the adapted shelving unit truly sufficient to be used safely as a dollhouse for children?
Absolutely: safety is the top priority for kids! Maybe also secure the back panel as well, so it’s less likely to tip over.
Keep at it, this will be a great project! 🙂
poted
23 Mar 2018 21:09
Very interesting topic! The stability of a KALLAX shelf used as a dollhouse largely depends on how the shelf is ultimately used and modified. In general:
1. KALLAX is made from laminated wood-based panels (similar to particleboard) and is fairly sturdy, but it is not designed to be used as a walk-in piece of furniture.
2. The standard KALLAX has an average load capacity per shelf of about 13 to 15 kg (29 to 33 lbs). Adding additional interior walls can improve load distribution and stability – but only if they are securely fastened.
3. For conversion into a dollhouse, it is advisable to reinforce the back panel (e.g., with OSB boards or battens) to reduce sideways bending and tipping.
4. Depending on how the roof and interior walls are attached, adding extra screws, brackets, or wooden strips in the corners can significantly increase safety.
5. The floor surface and whether the shelf is, for example, fixed to the room wall also play a role.
-> My question for you: What exactly does your conversion look like? Will the shelf be freestanding, or do you plan to secure it? How will the child use the dollhouse (standing, sitting, climbing)?
Such details help to better assess the stability and minimize potential risks.
LAGAU
24 Mar 2018 07:37
Thank you for the responses so far!
poted schrieb:
-> My question to you: What exactly does your modification look like? Will the shelf stand freely, or do you plan to secure it? How will the child use the dollhouse (standing, sitting, climbing)?
The shelf will stand freely but will be fixed to the wall with a few brackets to prevent tipping. The child will likely sit or kneel and may lean slightly against the shelf, but it is not intended as a climbing structure.
I plan to add interior walls in three of the compartments and install a lightweight roof, which won’t bear any load—more for aesthetics. I’m thinking of reinforcing the back panel. Screws, brackets, and battens are available.
I understand that the KALLAX is not designed as a play equipment, but I want to make it as safe as possible. Are there any special precautions I should consider? Or materials I should use for reinforcement that won’t add much weight?
barge
24 Mar 2018 09:26
Here’s a bit of reassurance with a touch of fun 😊
KALLAX is truly a space-saving marvel and something like the Swiss army knife among shelving units. I once had a project where I converted it into a mini playhouse (not for kids, but almost ;-)).
LAGAU schrieb:
The shelf stands freely but will be secured to the wall with some brackets to prevent tipping.
Very smart! Wall anchoring is the key to preventing tipping, and if you add baseboards or non-slip pads underneath, it will also stand securely on different floor types.
Interior walls and lightweight roof structures can even improve stability – as long as you don’t overload the shelf with heavy items.
My tip: If you’re painting or staining the conversion, use light coatings. Heavier stains can damage the surface and make the material brittle.
In the end: KALLAX is not a climbing tower, but a creative dollhouse can be really fun 🙂 Good luck!
bente
24 Mar 2018 10:53
I think it’s really important that you are putting so much thought into safety. As a parent, I can tell you that especially with children’s furniture, unexpected things often happen. My son recently used a similar shelf as a hiding place, and luckily it held up, but I also added extra brackets and secured it to the wall.
nedagla schrieb:
That’s brilliant! 🙂
That’s exactly what I want to say – projects like this are great, but it’s better to use one more screw than too few.
Have you considered adding edge protection profiles made of plastic? Even when it comes to stability, small details like these can prevent accidents later on.
I hope your dollhouse turns out as sturdy as you need it to be!
