ᐅ KALLAX Back Panel Clamped in Several Places – Will It Still Hold?
Created on: 7 Nov 2017 08:37
gino54Hello everyone, I have a question about the stability of my KALLAX back panel. During assembly, I noticed that the back panel was inserted between the side panels in multiple places—not just once, but in at least three spots at the same time. Now I’m wondering if this kind of attachment affects the basic stability of the shelving unit or if it’s generally not a problem. The back panel seems to be firmly in place, but I’m unsure whether the material is being stressed or warped over time. I mainly use the unit as a room divider and want to make sure the construction remains secure in the long term, especially when some weight is placed on top. Does anyone have experience with this or can provide technical insights? Thanks in advance!
V
valerie-tr7 Nov 2017 09:42Your observation is very interesting. Essentially, the back panel of KALLAX shelves is designed as a stabilizer that, by being tensioned between the side panels, prevents the shelf from tipping sideways or twisting. Clamping it at multiple points can even have a positive effect, as the back panel then distributes pressure and loads more evenly. However, you should ensure that it does not become excessively deformed. If the back panel has swollen or developed waves due to frequent clamping on the cardboard edges, this can reduce its load-bearing capacity. It is also important whether the back panel has been fixed with nails, staples, or screws—in KALLAX, this is usually done with small nails or staples that can break easily. If you use the shelf as a room divider and place weight on top, it helps to reinforce the back panel additionally with brackets or small wooden supports. I would be interested to know: Was the back panel only clamped multiple times between the boards, or was it also nailed or fastened at the edges? And how thick is the back panel in your case? Usually, it is about 3 mm (0.12 inches) thick plywood, which is not very flexible.
It is interesting to consider whether this multiple clamping of the back panel actually makes the shelf unit more stable in the long term or if it poses a risk of material fatigue. It is often assumed that a tight fit is automatically beneficial, but especially with thin particleboard panels, high pressure at several points can weaken the material and lead to later failure. Additionally, the back panel could be under tension in this way and distort the shelf unit, which could cause problems under load. Are there reliable experiences or studies regarding the load limits the KALLAX back panel can withstand when fixed in this manner? I would recommend measuring the load at different points and, if necessary, providing additional support with metal brackets or a continuous frame.
valerie-tr schrieb:
Was the back panel only clamped multiple times between the boards, or did you also nail or fix it along the edges? The back panel is only clamped multiple times, no nails or screws. The material is the usual thin fiberboard, as you described.
Neogi schrieb:
Are there any reliable experiences or studies about the load limits the KALLAX back panel can withstand with this type of fixing? Unfortunately, I haven’t found anything reassuring or clearly helpful on this. That’s why I’m asking here, to gather some practical experience. The shelf doesn’t carry too much weight; there are a few books and decorations on the upper part, but nothing heavy. Still, stability is important to me—I want to avoid any surprises from warping or the back panel coming loose.
