ᐅ KALLAX as an active dust collector – how to prevent it?
Created on: 9 Jun 2023 08:23
dinafe
dinafe
9 Jun 2023 08:23
I have a KALLAX shelving unit from IKEA that, despite regular dusting, always seems to attract dust actively. Especially in the open compartments, dust accumulates quickly, which really bothers me because it no longer looks appealing and also affects household members with allergies. I’m interested to know how others manage this issue: What measures or tricks are there to keep the KALLAX shelving unit free from dust in the long term? For example, are there proven covers, special cleaning products, or alternative uses that help minimize dust buildup and accumulation? I look forward to your tips and experiences!
draleo
9 Jun 2023 08:37
To reduce dust on open KALLAX shelves, I recommend regularly wiping the surface with an electrostatic microfiber cloth. These cloths capture dust more effectively than traditional feather dusters.
Additionally, acrylic glass fronts or cabinet doors are useful retrofit options. For example, IKEA offers KALLAX inserts with doors that close the compartment well, significantly reducing dust entry. Alternatively, transparent plastic sheets can be attached with Velcro strips to avoid completely blocking the view.
The location of the shelf is also important: near windows with a lot of drafts or in dusty rooms, dust can accumulate more quickly.
CARLA
9 Jun 2023 09:15
I agree with the recommendation to use doors. Additionally, it helps not to overload the KALLAX unit. The more items placed on the shelves, the more dust can accumulate.
Regular ventilation and maintaining humidity levels around 40-60% also help reduce dust in the air.
Another tip: vacuum the floor beneath the shelving regularly, as a lot of dust collects there, which can rise and settle on the shelves.
Aimee
9 Jun 2023 09:27
Dust accumulation is minimized by closing shelving units with boxes. Plastic or fabric boxes work very well.
Using a microfiber cloth for wiping and having an air filter in the room are also effective.
Marlenepa
9 Jun 2023 11:02
Dust on the KALLAX shelf is a common issue that affects many people, especially with open storage systems. I would recommend, in addition to using doors or boxes, paying attention to how often and with what you clean. Many use laminate or wood care products that leave residues and attract dust.
It is often better to wipe frequently with a dry, high-quality microfiber cloth. If allergies are a concern, regularly ventilating and vacuuming with a vacuum cleaner equipped with an air purification filter (HEPA filter) can help.
One more tip: If the shelf is to remain open, a light, breathable cover made of cotton or linen that can be removed and washed is beneficial.
gregto
9 Jun 2023 12:33
In addition to the tips mentioned, I would recommend the following measures:
1. Use of anti-static sprays that can reduce dust accumulation.
2. Check if there are carpets or highly dust-prone surfaces nearby that increase dust in the room.
3. Air purifiers with HEPA filters can reduce dust exposure in the long term.
It is important not to place the KALLAX directly near doors or windows that are often opened.
