ᐅ Kallax Shelving and Uneven Walls – How to Compensate?
Created on: 12 Dec 2015 16:22
harmko
I am facing the issue of installing a Kallax shelf unit on a wall that is unfortunately quite uneven. You can clearly notice this because the shelf wobbles in some spots or does not sit flush against the wall without some kind of compensation. My question is: What are the best ways to neatly and permanently level out such wall irregularities so that the shelf stands stable and straight? I am interested in both mechanical solutions like shims or spacer pads, as well as possible adhesive or filler techniques that can be usefully applied.
I want to avoid having to make readjustments after a short time or having the appearance suffer. If anyone has experience, tips, or even step-by-step guides on how to best proceed with Kallax shelves, I would be very grateful. Ideally, I’m looking for a method that is easy for non-professionals to carry out.
Thank you in advance!
lis64
13 Dec 2015 11:26
For uneven walls, it is often helpful to attach the shelf to a mounting board, which you first level with filler. Then you install the shelf onto the board – this way, you have a continuous, flat surface.
harmko
14 Dec 2015 08:13
PRA64 schrieb:
With careful preparation and choice of materials, you can reliably level out unevenness in walls and floors.
Thanks for the guide, it sounds like a solution I can easily implement. Could you possibly explain the principle with the mounting board in more detail? I’m wondering if it would make sense to attach a thin plywood board to the wall, which I would then fill (or sand) beforehand and afterwards attach the Kallax shelving unit to it. Is there anything I should watch out for when filling or fixing the board?
What type of filler material do you recommend for wooden boards to create a smooth, load-bearing surface? And how can I prevent the board from warping due to wood moisture? Thanks!
PRA64
14 Dec 2015 09:52
harmko schrieb:
Could you possibly explain the principle of the mounting board in more detail?
Gladly!
1. Material choice: Plywood or MDF with a thickness of 10-15 mm (0.4-0.6 inches) are well suited. Make sure the board is as warp-resistant and stable as possible.
2. Preparation:
- Treat the board with a wood preservative (e.g., linseed oil or wood protective glaze) to prevent swelling or warping.
- Then allow it to dry thoroughly.
3. Filling work:
- Use a high-quality, flexible wood filler that can accommodate wood movement.
- Apply thin layers and sand smooth between coats to create an even surface.
4. Fastening:
- Securely screw the board to the wall, preferably with anchors suitable for older walls.
- Ensure the board sits flush and is not pinched.
5. Installing the Kallax:
- Attach the shelving unit to the mounting board using appropriate screws or brackets.
- This provides a flat support and reduces the effects of wall unevenness.
Tip: If you want to customize the color of the board, you can paint it or cover it with adhesive foil afterward. This will give it a more polished look.
I hope this helps! Feel free to ask if you have any more questions.
