I recently assembled a KALLAX shelf unit from IKEA, but like many others, I am struggling with the adhesive residue that stubbornly remains on the painted surfaces after removing the protective film. My specific question is: Does anyone have an effective method or recommend a particular product to remove the KALLAX adhesive residue without damaging the surface?
I am especially interested in suggestions that work well on the white version and are gentle on the material. I want to avoid harsh solvents, as I intend to use the shelf for a long time and do not want to risk any discoloration.
Thanks in advance for your experiences and tips!
kaju67 schrieb:
What worked quite well for me: chew gum, stick it on, wait a moment, then peel it off.This "gum method" is more of a curious lifehack, but on a smooth surface, it can actually help remove small adhesive residues.
For a professional and low-risk removal, I recommend focusing on proven agents like isopropanol or WD-40, as already mentioned.
Also: Always ensure good ventilation when working with adhesive removers.
Foster63 schrieb:
This "chewing gum method" is more of a quirky lifehack Why not? Sometimes the simplest tricks are the most effective, and less is more.
I also wonder if this whole "we protect the shelf with films" is just a marketing ploy that delays removal and annoys customers. Who really wants adhesive residue that’s only potentially created?
Maybe we should just accept that a bit of adhesive is part of using it? That doesn’t stop any surface from looking good 🙂
theota schrieb:
Maybe we should just accept that a bit of adhesive is part of the process?This might be a divisive opinion, but from a customer’s perspective, I see it differently. Adhesive residue is avoidable, and both manufacturers and users should adhere to standards when removing it.
It is important to respect the material and its surface compatibility and to use the appropriate cleaning methods.
I believe it’s worthwhile to share tips like these to achieve the best results with minimal effort and without causing damage.
One more technical tip: If you use WD-40, make sure the surface does not absorb any moisture.
Afterwards, it is best to polish with a lint-free microfiber cloth. This prevents streaks and ensures a clean, undamaged surface.
Also, avoid applying too much pressure to prevent the film from being worn off.
edisondan4 Jul 2020 16:48onMarcos schrieb:
then best to polish again with a lint-free microfiber clothThat is an excellent tip. Microfiber cloths are ideal due to their structure for removing adhesive residues without scratching.
Summary of my recommendation:
- Hair dryer for heat
- WD-40 or isopropanol (tested carefully)
- Microfiber cloth for cleaning
This approach keeps surfaces undamaged and clean.
