I have a problem with my IKEA Malm furniture. When removing some drawers and taking off old self-adhesive labels, adhesive residue was left behind that cannot be easily wiped away. Since I don’t want to damage the surface, I’m looking for a gentle yet effective way to reliably remove these old adhesive residues.
Does anyone have experience with Malm furniture or similar coated surfaces? Which household remedies, cleaning agents, or technical solutions would you recommend that are both effective and safe for the material?
Looking forward to your tips and suggestions!
Regarding adhesive residue on Malm furniture, I would like to add the following:
It is important not to expose the piece of furniture to high heat immediately after treatment. Heat can soften the adhesive, but excessively high temperatures can also damage the surface foil.
Therefore, I recommend using, for example, a hairdryer on a low setting and at some distance to gently warm the adhesive. This often makes it easier to remove with a soft cloth or plastic scraper.
Always test on an inconspicuous area first to avoid any discoloration.
Cleaning afterward with mild dish soap and a soft cloth completes the care process well.
As for me, I did some reading and experimenting – besides oil and denatured alcohol, isopropanol (rubbing alcohol) also works very well on adhesive residues on plastics. Just apply it to a soft cloth, test it on a small corner, then gently rub off the residue. It usually allows for better control than denatured alcohol and dries quickly.
And don’t worry, a bit of tact and patience almost always leads to success here 😉.
KNUTGI schrieb:
Isopropanol (cleaning alcohol) is very effective for removing adhesive residues from plasticsExactly, this tip is really useful. You can easily try it out, especially with MALM furniture.
Sometimes it also helps to wipe down again with a damp cloth after using isopropanol to ensure no residue remains. And always remember: less is more—gentle cleaning is key! 🙂
vin_leo schrieb:
Sometimes it also helps to wipe again with a damp cloth after cleaning with isopropanolThis is an important point. Although isopropanol residues are minimal, they can alter the paint if left on for an extended period, especially if the surface is already weakened.
In general, the priority during all cleaning steps is to protect the surface and avoid overstraining it. Therefore, always test first in an inconspicuous area to check the reaction and compatibility.
Thank you all for the very helpful, well-structured, and practical advice.
I will try the approach with oil (most likely baby oil) and then possibly isopropanol, of course carefully and testing on an inconspicuous area first. The tips about using plastic putty knives and avoiding aggressive solvents came at the right time.
If the adhesive residue proves particularly stubborn, I would like to know: Are there any experiences with using a melamine sponge (Magic Eraser) on MALM? And how vigorously can I use it without damaging the surface?
