ᐅ Is there a guide for using IKEA PLATSA as a shoe cabinet?
Created on: 6 Oct 2020 08:24
rube40
rube40
6 Oct 2020 08:24
Good morning everyone,
I am currently considering converting my IKEA PLATSA wardrobe into a shoe cabinet. My specific question is whether IKEA or perhaps the community has any tailored instructions or at least reliable tips on how to best use the modules and shelves for shoe storage.
I am looking for a practical and sturdy solution, as shoes tend to be somewhat heavy, and proper ventilation is important when the cabinet is closed. Does anyone have experience or know of trustworthy guides explaining how to best plan and assemble the PLATSA wardrobe as a shoe cabinet?
I would appreciate any advice, especially regarding the arrangement of compartments or special inserts recommended for this purpose. Thanks in advance!
mopra42
6 Oct 2020 10:12
As far as I know, there is no direct guidance from IKEA.
I recommend:
- Use different shelf heights for various types of shoes.
- Use metal or wooden shelves that are sturdy.
- Ventilation can be achieved through open modules or small ventilation holes, if you are able to drill.
Le_kin
6 Oct 2020 13:47
Regarding using PLATSA as a shoe cabinet, there is no official IKEA instruction, but I have analyzed several variations online and tested them myself. The most important points are:
- Compartment height: For regular low-cut shoes, 20–22 cm (8–9 inches) is sufficient; for tall boots, 35 cm (14 inches) or more is recommended.
- Stability: The shelves are usually made of MDF; for heavier loads, I suggest reinforcing them with metal profiles or attaching additional supports.
- Air circulation: Since PLATSA fronts are often closed, adding vents or perforated back panels helps prevent mold formation.
There is probably no specific PDF instruction available, but many users combine the modules freely and use a rotary tool or drill to create custom ventilation holes.
If you’re interested, I can create a customized layout plan for you if you provide your room dimensions and the number of shoes.
BAUEVA
6 Oct 2020 15:02
Le_kin schrieb:
There is probably no specific guide available in PDF format
This is exactly an important insight. It raises the question of whether a fixed set of instructions even makes sense for the flexible PLATSA modules.
Every use as a shoe cabinet will be different—depending on size, number of shoes, and types of shoes.
Therefore, it is worth critically considering whether a standard approach is needed or rather a kind of modular system. Your willingness to adapt to dimensions and the number of shoes is a reasonable approach.
One more point: What about the long-term stress on the materials? Shoes are heavier than clothing, and especially the hinges, shelves, or interlocking systems should be adequately tested for this load.
semuneo
7 Oct 2020 09:33
I find this topic really interesting because I’m also considering using PLATSA as a shoe cabinet.
For me, it’s especially important to find a solution that looks good but is also practical for everyday use. Shoes take up a lot of space, and if everything is too cramped or lacks ventilation, it can quickly become unpleasant.
BAUEVA schrieb:
Each use as a shoe cabinet will be different – depending on size, how many shoes, and the type of shoes.
I agree with that. I’m curious if anyone has experience with ventilation solutions in a closed PLATSA cabinet? I’m thinking about whether it’s possible to add something like ventilation grilles without ruining the appearance.
Looking forward to more tips!
bupar
7 Oct 2020 11:45
Regarding load capacity and functionality:
- PLATSA is designed as a modular room divider and cabinet, not specifically for heavy loads such as shoes.
- The shelves are usually made of coated particleboard or MDF, which can bend depending on the depth and the weight of the shoes.
- To increase stability, it is recommended to install additional supports or choose the firmer back panel versions.
- Ventilation can be achieved by carefully installing ventilation grilles, preferably discreetly and in less visible areas.
There is no specific manual, as the modification depends on individual planning concerning equipment, frequency of use, and shoe volume.
My advice: First, precisely measure your own situation and then design a customized solution instead of relying on a standard guide.
