ᐅ Is there a replacement available for defective hinges on the KALLAX unit?
Created on: 12 Oct 2024 08:43
JUSTUS59
JUSTUS59
12 Oct 2024 08:43
Hello everyone, I have a KALLAX shelving unit from IKEA with doors, and unfortunately, one of the door hinges has defective plastic joints, which apparently happens quite often with frequent use. My question is: Are there replacement hinges or alternative options to fix damaged hinges on the KALLAX unit without having to replace the entire door or the whole piece of furniture? I am especially interested in whether there are compatible replacement parts available from IKEA itself or if you can rely on third-party or universal versions from hardware stores or online shops that fit without any issues. Thanks in advance for your opinions and experiences!
juMira46
12 Oct 2024 09:12
Hey Justus59, that’s a pretty practical question! 😊 From my experience: IKEA itself offers replacement hinges, but usually only in sets, and sometimes you have to search a bit because they’re not prominently sold individually. If the original hinge is broken, you can also check major online retailers or specialized furniture and hardware stores – they often have compatible universal hinges that can fit with some adjustments.
A tip: sometimes small modifications or using hinge plates can help to install universal parts. It’s worth the effort if you love the piece of furniture and don’t want to buy a new one :-) Good luck!
Marcellela
12 Oct 2024 10:25
IKEA replacement hinges are usually available through customer service. Otherwise, check your local hardware store: obtain and install standard hinges with the same dimensions. Important: measure the hole spacing!
Jensson
12 Oct 2024 11:57
Hello Justus59, I would like to structure my response a bit more systematically:
1. Original IKEA replacement parts: It’s worthwhile to contact IKEA directly about the specific hinge model. These are usually available as spare parts, even if they are not listed in the catalog.
2. Taking measurements: A hinge has typical dimensions (hole spacing, depth, opening angle) that are crucial for compatible alternatives.
3. Third-party suppliers: Some sellers on platforms like Amazon or eBay offer universal hinges with similar dimensions. Here, it is important to pay close attention to quality and reviews.
4. Installation: The new hinge should fit without major drilling to avoid compromising the door’s stability.
I recommend contacting IKEA first, then searching at your local hardware store or online using exact measurements. If you are interested, I can provide a more detailed guide on measuring and installation.
Paunon
12 Oct 2024 14:03
Of course, replacements are available. IKEA sells most hinges individually. If you can't find the original, use standard hinges with the same hole spacing. Important: Make sure the borehole diameter is 35mm (1.4 inches).
Palenar
13 Oct 2024 08:22
Hello Justus59, your question is very relevant, as many IKEA users face this issue.
Regarding the specific topic: KALLAX units with doors usually use special types of hinge mechanisms, such as folding or soft-close hinges, which are based on standard furniture fittings but often have unique dimensions or plastic covers. Defective plastic components typically cause the hinge function to fail.
Replacement from the manufacturer:
IKEA offers replacement hinges for many of their furniture pieces, but these are not always easy to find online. The best approach is to contact customer service directly or visit an IKEA store about a week in advance.
Alternative options:
- Universal hinges from hardware stores that mechanically fit (hole spacing, cup radius).
- Use of mounting plates to adapt to the installation surface.
- When replacing, measure exactly: depth of the hinge cup, diameter of the drill hole (typically 35mm (1.4 inches) for furniture hinges), distance between the holes.
A common challenge is the opening mechanism: some KALLAX hinges are soft-close dampers, which cheaper universal versions may lack.
One more question for you: What exactly does the damage look like? Is it only the plastic joints or multiple material failures? This might influence the choice of material for the replacement part.
